HID H4 Bi-xenon 6000k for sale.
Hi guys,
I have a 6000k HID Kit in H4 shape which is the bi-xenon, so full beam and dipped lights, for anyone who has the double filament fitting. £50 as these are quite expensive for full beam and dipped.
(THIS IS THE MAIN PRIORITY!)Or I can do a straight swap for a set of HB7 (The one in IS200)
Thanks
Phil01 Hi guys,
Thanks
Quote:LEXUS IS200 99-
Dip Beam - 9006/HB4
Main Beam - 9005/HB3
Sidelight - 501w /T10/W5W
Side Turn - 501w /T10/W5W
Front Fog 99-2003 - 9006/HB4
Front Fog 2003- H3
Sportcross front fog - H3
Rear High Mounted Stop Light - 955 / T15
Licence Plate - 501w /T10/W5W X 2
Rear Fog - T20 /7440
Reverse light - T20 /7440
front indicator - 582
Rear indicator - amber 581
Stop/Tail - 7440/ T20/ w21/5w
Interior Middle Dome - 269 /festoon 31mm
Interior Front - Ba9
Glove Box - R286 / 5mm
Ignition barrel ring - R286 / 5mm
Door Marker lights - 501w /T10/w5w
Boot Light - 501w /T10/w5w
Phil01 Hi guys,
Thanks
Dip Beam - 9006/HB4
Front Fog 2003- H3
Marsdendean the HB4 will fit in the IS200, couldnt you wire the dipped and main into one headlight bulb?
Pm'd.
I have an idea in mind.
But mate I thought the h4 was double filament and h7 was single filament, and the b means bayonet so that wouldn't affect the number of filaments. Also mate I want the dipped. And was the pm to ne as I have none.
Thanks
Oli But mate I thought the h4 was double filament and h7 was single filament, and the b means bayonet so that wouldn't affect the number of filaments. Also mate I want the dipped. And was the pm to ne as I have none.
Thanks
Thanks
Cant reveal my ideas in advance can i
