JapCarForum General Discussions The JCF Lounge Ceramic Coating and HT Leads worth it?
09-01-2017, 01:29 PM
as above worth the money
answer with reasons please
thanks
09-01-2017, 01:29 PM #1
thanks
09-01-2017, 01:36 PM
Ceramic coating a def yes!
as for HT leads, your best changing to individual coil packs like the IS has but yes uprated ones are worth it.
09-01-2017, 01:36 PM #2
09-01-2017, 01:40 PM
right i see. the v8 has two coil packs. one for 4 sparks plugs.
thanks Stav will keep that in mind.
09-01-2017, 01:40 PM #3
09-01-2017, 02:01 PM
Asi right i see. the v8 has two coil packs. one for 4 sparks plugs.
yeah with the individual coil packs it s a lot easier to adjust timing of the sparks exactly for each cylinder
09-01-2017, 02:01 PM #4
09-01-2017, 02:02 PM
true true. any idea how would i be able to get individual coil packs?
09-01-2017, 02:02 PM #5
09-01-2017, 02:23 PM
you can buy them mate, a lot of companies do them
alternatively maybe the IS ones fit?
Thor do them: http://www.thor-racing.co.uk/SplitFire-295.asp
see what theyve done with their V8 maybe?
09-01-2017, 02:23 PM #6
09-01-2017, 11:24 PM
Ceramic coating is a definetely yes. I am planning to do it too
09-01-2017, 11:24 PM #7
10-01-2017, 02:19 AM
Ceramic coating for what though ? The manifold ? The turbo ?
10-01-2017, 02:19 AM #8
10-01-2017, 02:20 AM
The manifold mate.
10-01-2017, 02:20 AM #9
The manifold mate.
10-01-2017, 02:24 AM
and the exhuat housing of the turbo can be done as well. though a blanket is easier.
also the down pipe is good to get ceramic coated as well
10-01-2017, 02:24 AM #10
Replies 27
Views 1,220
08-03-2019, 06:49 AM
Last Post by S
Views 420
10-01-2019, 07:23 PM
Last Post by clossie
Views 479
25-01-2018, 11:47 AM
Last Post by widnes_is200
Views 584
08-12-2017, 10:42 AM
Views 340
10-06-2016, 06:21 AM
