JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Few pictures of a stripped down TTE Superscharger.
Pages (3): 1 2 3 Next
rob
10-01-2017, 11:40 AM
This all started after hearing some strange sounds when driving slowly around the city - I would hear a grating sound, I thought it might be the Kompressor so after a bit of investigation I found that the bolts for the Kompressor drive were missing so the modified magnetic clutch plate drive was not driving which means no boost pressure... After a closer look I saw the drive bolts on the Kompressor pulley had sheared and I also found that the pulley bearing had some play so I decided to strip and replace all the bearings I could in the Kompressor
some photos for you....
Photo's removed by owners request, if anyone wonting to look at these photo's please send Rob a pm .... Gord
Edited 31-12-2010, 07:09 PM by GH.
rob
10-01-2017, 11:40 AM #1
10-01-2017, 11:42 AM
Nice review Rob, do you have the part number or the dimensions of the oil seal?
10-01-2017, 11:42 AM #2
looking very nice. should have got cermaic coating would have helped?
10-01-2017, 11:42 AM #3
rob
10-01-2017, 11:45 AM
dimis Nice review Rob, do you have the part number or the dimensions of the oil seal?
Sorry Dimis, i dont anymore, It was a common size and I had no problems finding it.. thats all i can really say.. But didnt you buy a new unit a while ago???
rob
10-01-2017, 11:45 AM #4
10-01-2017, 11:49 AM
Yes I did, i was just curious bucause i never managed to find this part
10-01-2017, 11:49 AM #5
rob
10-01-2017, 11:50 AM
no probs..... i will take it down at some stage and update it as i found some new pics which i have to upload at some stage.
i have taken it down from LOC to do the same and then will re post it.
rob
10-01-2017, 11:50 AM #6
rob
10-01-2017, 11:51 AM
dimis Yes I did, i was just curious bucause i never managed to find this part
i looked everywhere and couldnt find it either - in the end i removed the original and just measured it - i paid less than 1 euro it i remember
rob
10-01-2017, 11:51 AM #7
10-01-2017, 11:53 AM
I was going to do the same, but i found and bought the new SC so i never ended up dismantling the sc.
10-01-2017, 11:53 AM #8
10-01-2017, 12:14 PM
You can get the needle bearings from ebay.
http://cgi.ebay.com/ebaymotors/Eaton-M62...ccessories
These are the ones i bought to service my first eaton sc.
10-01-2017, 12:14 PM #9
rob
10-01-2017, 12:16 PM
the rear bearings are easy to get there is a guy on US ebay drassolic or something like that is his user name.
FORGET the front bearings as they are a really odd sie and the seals are even stranger.
The main bearing took a bit of finding but i found alternatives and its used in aircon pulley clutches, but they can be found easier now than before..
EDIT: Dimis beat me to it.
rob
10-01-2017, 12:16 PM #10
