Facia & amp bypass lead
Just a quick question, ive seen a few on ebay with quite a difference in price for both items ranging between £10-£40.....am i right in thinking they are all the same?
Thanks
No some are for the "S" model the one without a separate amp.
The one you want assuming yours is an SE or Sport is: LINK
otherwise just an MR2 one will do the trick!!
Yeap got an SE, so isnt this the same?? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...0103888218
it reads like the right one, however it is a bit on the cheap side, the one I have linked to is a good quality item and also the one I have installed.
However if it is correct you have saved £20!! It is difficult to fit unless you have slim hands - just a warning...
Yeah thats what i thought, it reads right.....just called the shop and he selling it for £22 in the shop.......will get it and if its not the right one will take it back, its not far from me.......he's also got the facia for £16 http://cgi.ebay.co.uk/Lexus-IS-200-300-S...27af1a0b01.....not bad £30 all in delivered for both!
Seeing as it's an autoleads item, it can't be any different wherever you buy it? I'd go with the cheapest one you can find if you're still buying the same part.
parthiban Seeing as it's an autoleads item, it can't be any different wherever you buy it? I'd go with the cheapest one you can find if you're still buying the same part.
Best of luck, DJWozza has a guide to doing the amp bypass so PM him if you need advice.
