JapCarForum Car Manufacturers Toyota steering prob
steering prob
steering prob
paramedic
15-01-2017, 01:37 PM
hi any body out there could you please help me/my car.
problem is -approaching a bend / or somtimes going straight ahead and applying my foot brake to stop the car sometimes it pulls severly to the right or
sometimes to the left , but applying the foot brake foot brake couple of times slowly seems to fix it . but it unexpected can can happen any time.
but normaly it drives fine ,if tha makes sense !
i hope some out there can sort it .
thanks
paramedic
Edited 26-02-2010, 11:26 PM by paramedic.
paramedic
15-01-2017, 01:37 PM #1
thanks
paramedic
kam05
15-01-2017, 01:38 PM
tracking/wheel alignment/suspension issues?
kam05
15-01-2017, 01:38 PM #2
paramedic
15-01-2017, 01:41 PM
kam05 if its anything you mentioned mate it would happen all the time'; but as i said it sometimes happens !
paramedic
15-01-2017, 01:41 PM #3
15-01-2017, 01:54 PM
At a guess mate i'd say a sticking brake calliper piston/pistons, which sticks when you brake normally so it pulls to the side, but under heavy braking it has enough pressure to force the piston out so it brakes more even? You'll probably find when you do the pads it'll be fine for a bit, until the pads start to wear then it'll start to happen again? so they might just need a good service?
15-01-2017, 01:54 PM #4
paramedic
15-01-2017, 01:59 PM
bandit, when you say its the pistons they are a bit rusty, is there anything i can do to sort out the prob because sometimes when i am not expecting it it can be dangerous and i am always holding the steerig wheel with both hands just in case.
Edited 26-02-2010, 11:44 PM by paramedic.
paramedic
15-01-2017, 01:59 PM #5
paramedic
15-01-2017, 02:06 PM
bandit how can one service ones calipers/pistons , if you think that could be the cause it seems to make sense ,mate !
the pads are running a bit low thats the reason why i asked the first question on thi forum, about which pads are ideal for my car.
Edited 26-02-2010, 11:45 PM by paramedic.
paramedic
15-01-2017, 02:06 PM #6
15-01-2017, 02:11 PM
Here you go mate have a little read of this, it'll explain it a lot better than me about the caliper service, :laugh:
CLICK ME?
It sounds like the pistons could do with a clean, so that there moving freely within the caliper itself?
The new pads should help, but you'll probably find it'll return after a bit of use when the pads wear down again?
15-01-2017, 02:11 PM #7
CLICK ME?
15-01-2017, 02:21 PM
pistons dont really suffer from sticking mate wouldnt hurt to clean them though, but the slides do seize a lot......
i'm a toyota tlt mate cleaned up/replaced many slides.
15-01-2017, 02:21 PM #8
paramedic
15-01-2017, 02:23 PM
thanks bandit i do appreciate your help :thumbup1:
paramedic
15-01-2017, 02:23 PM #9
paramedic
15-01-2017, 02:26 PM
ormi, but i cant see why the pistons are rusty! (what are the slides)
paramedic
15-01-2017, 02:26 PM #10
