JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! Dash cluster removal
01-02-2017, 02:46 AM
this has come up alot so thought id post a how to sorry about the pics
and sorry if im stepping on toes hereBlush
first put the steering wheel to the lowest setting
there are 3 screws holding in the cover
remove the 1 below the ignition barrel
[Image: dsc04386.jpg]
then remove the 2 at the top of the cover
[Image: dsc04385.jpg]
pull the cover towards you gently which should expose the clips
[Image: dsc04390d.jpg]
these should just pull out
remember there is the connector to the dimmer switch on the other side which you will need to remove
[Image: dsc04394g.jpg]
once this is disconected it should just slid off to expose the dial cluster
[Image: dsc04395m.jpg]
there are 3 screws holding this in place
[Image: dsc04396xy.jpg]
[Image: dsc04397m.jpg]
[Image: dsc04398ud.jpg]
remove all 3 and pull it out gently
there are 2 block connectors on the back remove these and the dials should come out
[Image: dsc04401r.jpg]
once out if you are replacing the bulbs you require 2 T5's and 3 T10/501 bulbs
[Image: dsc04352d.jpg]
and once done replace and test the new bulbs for correct polarity if they dont work turn them round
finished item
[Image: dsc04357r.jpg]
hope this helps alot of people out
01-02-2017, 02:46 AM #1
finished item
01-02-2017, 02:49 AM
Great walkthrough ! :thumbup:
01-02-2017, 02:49 AM #2
01-02-2017, 02:58 AM
Great walk through:thumbup1:
This is the kind of walk through the club love so keep them coming:thumbup1:
01-02-2017, 02:58 AM #3
01-02-2017, 03:32 AM
nice thanks mate
01-02-2017, 03:32 AM #4
nice thanks mate
01-02-2017, 03:42 AM
Nice one mate, I'm sure that will come in handy if I eventually do this!
01-02-2017, 03:42 AM #5
01-02-2017, 03:48 AM
thanks for the replies
thought id give it a go putting a walk through on hope it all makes sense
1 thing you can also change the ignition barrel light well you do this its 1 T5 bulb
01-02-2017, 03:48 AM #6
01-02-2017, 04:21 AM
Nice and clear walk through matey :thumbup: always good to have on the forum and some rep added :thumbup1:
Edited 15-03-2010, 09:25 PM by Bandit.
01-02-2017, 04:21 AM #7
Fry-Up
01-02-2017, 11:21 AM
much easier to see what i'm doin than the pdf i'd looked at earlier
Fry-Up
01-02-2017, 11:21 AM #8
01-02-2017, 11:23 AM
Great walkthrough mate!
+Rep for you
01-02-2017, 11:23 AM #9
+Rep for you
Jambo
01-02-2017, 12:08 PM
Loving the blue there Smile
Latest Meets
Ace Cafe 16/10/10,
Jambo
01-02-2017, 12:08 PM #10
Latest Meets
Ace Cafe 16/10/10,
Views 598
25-06-2017, 02:39 AM
Views 1,527
30-04-2017, 03:22 AM
Last Post by Timbo
