JapCarForum Club Sponsor WHEELS-INMOTION Possible tyre wear issue? Tony/WIM?
Pages (4): 1 2 3 4 Next
08-02-2017, 06:00 AM
Hi Guys (Tony),
Had my IS200 since August 08 and have just come to the time to change my front tyres, upon inspection today I noticed that my front o/s and my front n/s have worn completely differently.
Having looked at the pictures of the tyres (see below) my o/s has worn badly on the inside and is lower in general than my n/s which has about 3mm of tread before the marker and my o/s is on or just below the tread marker.
Now as these tyres were on the car prior to me buying it i'm under the assumption that they were both changed at the same time so taking out of consideration that maybe due to a puncture or the tyres were changed at different intervals, dooes anyone have any ideas what could cause such a uneven wear?
The car is fully WIM'd (infact I think it was the guinea pig car for WIM) and Tony checked my tyres last year and could see even wear across them. I had a advisory on my n/s ball joint at MOT time as there was a little bit of play but not sure if this could cause any difference? I also remember that in Feb 09 (when we had all the snow) the car was parked up on the road side and a van hit my front o/s totalling the wing maybe this has nocked the geo out on this side explaining the odd wear on 1 side?
Some pics showing the differences below -
The o/s front
[Image: picture001ej.jpg]
The n/s front
[Image: picture002ev.jpg]
And the damage that happend to the front o/s
[Image: SP_A0128.jpg]
All help/advice would be appreciated
Ta
Dan
08-02-2017, 06:00 AM #1
Hi Guys (Tony),
The o/s front
The n/s front
Ta
Dan
TommyH
08-02-2017, 06:11 AM
It's highly likely that the knock put out your geo mate.
TommyH
08-02-2017, 06:11 AM #2
08-02-2017, 06:12 AM
my thoughts too mate penny dropped this afternoon after the pics, innitially I thought that 1 tyre had just worn more than the other, it was only when I put the wheels on full lock that it really showed the bad wear.
08-02-2017, 06:12 AM #3
08-02-2017, 06:30 AM
actual suspension hasn't felt out at all that's the weird thing no strange noises/nocks or anything not to say it's not bent though.
Have pm'd wim on here and sent Tony a message on facebook too, need this sorted asap.
08-02-2017, 06:30 AM #4
08-02-2017, 08:31 AM
DJ Wozza The WIM Hunter machine will pick up if a suspension component is bent I believe, although Tony will confirm ?
Yeap it does, asked Tony when I took the corolla in
08-02-2017, 08:31 AM #5
08-02-2017, 10:03 AM
well 2 new tyres fitted just awaiting Dr Bones to get back to me so I can get this geo looked at
08-02-2017, 10:03 AM #6
99
08-02-2017, 12:00 PM
As little as 10' of arc will dramatically effect the tyre wear, i think a combination of the poxy road condition and or the impact is responsible...... Need to get her booked in matey.
wheels-inmotion
08-02-2017, 12:00 PM #7
08-02-2017, 12:37 PM
Cheers Tony?
Whats the going rate for a recheck? as i've already on the WIM books :p
08-02-2017, 12:37 PM #8
Cheers Tony?
08-02-2017, 01:11 PM
WIM will give you a discount if you're a paid Outlaw member Dan :wink:
08-02-2017, 01:11 PM #9
08-02-2017, 02:39 PM
haha does the discount outweigh the outlaw membership though :p
08-02-2017, 02:39 PM #10
Views 630
28-04-2018, 05:07 AM
Last Post by CIH
