JapCarForum Cars, Cars, Cars! General Car Maintenance K&N Filter Cleaning
K&N Filter Cleaning
K&N Filter Cleaning
Pages (4): 1 2 3 4 Next
24-02-2017, 03:11 AM
Has anyone cleaned their filter? How clean does the cleaning kit actually make it, or would it be easier and better to just buy a new one?
24-02-2017, 03:11 AM #1
24-02-2017, 03:18 AM
have a look here bud ..............
http://www.lbcarco.com/cgi-bin/gen5?next...&a=&t=_top
24-02-2017, 03:18 AM #2
Bobby
24-02-2017, 03:20 AM
Clean it dont replace it, these should last for years
Cheers
Bobby
Shy boys don't get sweeties.
Bobby
24-02-2017, 03:20 AM #3
Cheers
Bobby
24-02-2017, 03:32 AM
Moley have a look here bud ..............
Cheers fella, very useful, however 50k miles is a long time:blink: i think ive bearly done 10k since it was fitted and its as black as :cursing:.......only checked the filter cause it seems to be idling a little low and has actually cut off at the lights?....or could there be another reason for this?
DJ Wozza Clean it mate, I did mine fairly recently, you can buy the kit from Ebay for about £10-£15
How many miles did you do before cleaning it mate?
24-02-2017, 03:32 AM #4
24-02-2017, 03:46 AM
If anyone wants to buy a K&N cleaning kit, I have one, and have no use for it now I've got a different filter/induction.
24-02-2017, 03:46 AM #5
24-02-2017, 03:49 AM
DJ Wozza Hmmm about 30,000. Remember to reset the ECU after you re-fit the filter Smile
filter was fitted around 2 years ago!!
So am i right in thinking that a dirty filter = low idle and possible cut off
24-02-2017, 03:49 AM #6
24-02-2017, 04:09 AM
For me, I would clean the K&N every service/oil change. Not a big job, and it should help the car keep running well. It could save you money too, i.e. via your fuel economy : biggrin:
24-02-2017, 04:09 AM #7
edeath
24-02-2017, 04:37 AM
I would clean it at every service seeing as the OEM one would normally be replaced.
edeath
24-02-2017, 04:37 AM #8
24-02-2017, 04:57 AM
DJ Wozza especially if used for short journeys too mate....
Also when was the last time the spark plugs were changed ?
Plugs were also changed 2 years ago.......right will give the filter a good clean along with the oil/filter change! Cheers lads:wink:
24-02-2017, 04:57 AM #9
Ally
09-03-2017, 04:43 AM
SHAHZ Plugs were also changed 2 years ago.......right will give the filter a good clean along with the oil/filter change! Cheers lads:wink:
Any news on your low idling Shahz? I have the same problem and i haven't cleaned my K&N since it was fitted 2.5 years ago :blushing:
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
09-03-2017, 04:43 AM #10
Views 1,035
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,421
02-04-2021, 11:15 AM
Last Post by 1374lee
Views 1,037
17-02-2021, 08:43 AM
Views 876
19-07-2019, 05:18 AM
Replies 24
Views 1,892
24-09-2018, 09:43 AM
Last Post by reco2k
