JapCarForum Car Manufacturers Toyota Replacement brakes
Replacement brakes
Replacement brakes
Fozzy
25-02-2017, 01:35 AM
I thought i would start to fill things out in here.
As my car has sh!tty front brakes that are stuck on, and hence pretty cooked from the drive home, they are the first parts to be replaced.
After a search around, i came across a group buy on MR2OC, from CRN performane, so hopefully in the next day or two i should be receiving a nice package.
I should have coming to me
EBC grooved front and rear discs, with yellow zinc plating finish
EBC ultimax pads front and rear
I have also ordered a caliper rebuild kit from Bigg Red. This will replace the piston seals and the slider pin seals.
Providing they turn up, i will documenting the work up on here this weekend
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
25-02-2017, 01:35 AM #1
25-02-2017, 02:21 AM
I'll be interested to see how this turns out - I royally f**ked up my braking system attempting to refurb calipers myself Smile That was rears though and they are unusually complex on these cars (don't use drums for handbrake).
I've used Brakes International for most of my brake parts so will be interested to see how this compares - I always use genuine toyota discs + pads though.
25-02-2017, 02:21 AM #2
Views 428
19-07-2019, 05:20 AM
Views 945
03-04-2018, 06:49 AM
Last Post by jimxms
Views 624
22-09-2017, 07:54 AM
Last Post by Bandit
Replies 43
Views 2,237
21-01-2017, 07:35 AM
