JapCarForum Cars, Cars, Cars! General Car Maintenance Cataclean for the rotary
Bobby
01-03-2017, 10:53 PM
Bought some of this, seems to get excellent write ups on the various Rotary/RX sites.
Here is the official blurb.
Used as a liquid service tool, CATACLEAN will first clean your vehicles fuel system, improving cylinder fuel burning in turn giving better performance in catalytic and non-catalytic Rotary engines.
CATACLEAN also cleans the carbon away that builds up inside the rotor housings and on the Rotors potentially leading to sticking tips and apex seals and thus improving compression
We genuinely know this liquid works to help aid Rotaries through the U/K MOT test with RX-8’s that have failed the emissions test then passing after adding CATACLEAN to their fuel tank and returning the following day, thus saving the £1100 required to renew an RX-8 catalytic converter ,then it cleans the surface of the catalytic converter improving gas flow and reducing emissions.
Cheers
Bobby
Shy boys don't get sweeties.
Bobby
01-03-2017, 10:53 PM #1
Cheers
Bobby
02-03-2017, 01:53 AM
Sounds like good stuff mate, always good to have a clean engine on the inside and helps to keep them in good working order :thumbup1:
02-03-2017, 01:53 AM #2
Bobby
02-03-2017, 03:00 AM
£11.99 a bottle, worth giving it a go I thought.
Cheers
Bobby
Bobby
02-03-2017, 03:00 AM #3
Cheers
Bobby
02-03-2017, 03:05 AM
Nearly cheaper than a gallon of petrol:biggrin:
02-03-2017, 03:05 AM #4
moomoo
02-03-2017, 05:16 AM
I used a bottle of Cataclean and some diepetane to try pass emmissions. Car went from 0.39 to 0.06 at high idleBig Grin well impressed:thumbup1:
moomoo
02-03-2017, 05:16 AM #5
fluff
04-03-2017, 12:09 PM
I saw this Cataclean on one of the shopping channels (I know, I hadn't had Sky before) and it did look quite good. Seems to actually do somthing which the others like Redx don't seem to do.
In the USA they seem to rave about this stuff called Seafoam. You put a third of the can in your petrol tank, a third in the crack case and you suck the last third up into the engine through the brake line booster. Leave it switched off for a few mins and then start it up. You get enormous amounts of white smoke. Some say it is the carbon burning away from your engine but I'm not so sure. Youtube it because it looks quite alarming.
Let us know how you get on with the cataclean as if it works I might shove a bottle into the LS. I'd hate to have to change the two pre cats and the one after if I didn't have to.
fluff
04-03-2017, 12:09 PM #6
01-04-2017, 01:01 AM
Bandit always good to have a clean engine on the inside
That's what water injection is for :lol:
01-04-2017, 01:01 AM #7
