JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Thermostat
Thermostat
Thermostat
LEX11S
02-03-2017, 08:47 AM
Hi boys and girls
been playing around with the standard thermostat (in the cars engine)
took it out and drilled 5 holes in the outside part put back.
The car ran alot colder to much it never got off cold start wooops!
Anyway got a new one and drilled just one 5mm hole in it the car now runs at
75c like the trd one and all for 10 pound.
As i have a turbo on the car its made a big difference
the heaters still work fine as well.
For those who want a colder running thermostat and dont want to spend the
money on a trd one.
Matt
LEX11S
02-03-2017, 08:47 AM #1
Hi boys and girls
money on a trd one.
Matt
02-03-2017, 08:49 AM
Hmmm OK now but in cold winter it will take longer to heat up.
02-03-2017, 08:49 AM #2
Chri5
02-03-2017, 09:38 AM
Is this a good idea???
Can't help thinking it's not.
Chri5
02-03-2017, 09:38 AM #3
02-03-2017, 10:38 AM
When you say it made a big difference because you've got a turbo, can you be more specific ?
02-03-2017, 10:38 AM #4
03-03-2017, 02:13 AM
Then again the turbo cars do run a significantly hotter then N/A ones so it could be a better option for keeping the water temp down.
03-03-2017, 02:13 AM #5
LEX11S
05-03-2017, 07:19 AM
yeah the car does run hotter than n/a just helps to keep it down
its only a 5mm hole so the car still takes the same time to warm up just it sits at 75c when driving and not 82c.
dont know about it when it gets cold but i always let my car warm up before i drive it.
LEX11S
05-03-2017, 07:19 AM #6
05-03-2017, 07:32 AM
I wonder if my old Lex would benefit from his mod?
05-03-2017, 07:32 AM #7
