JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Main beam HID
Main beam HID
Main beam HID
11-03-2017, 02:04 AM
One of my main beam bulbs has blown and I can't seem to find the PIAA bulbs I have anywhere anymore. So thinking what I should do, I know some have HIDs in their main beams, the HIDs4U kit I have in my dipped beams come to full brightness really quick so they'd be fine as main beams but don't really want to spend that much for something I don't use that often.
Will the really cheap kits (under £50) on ebay fire as quickly or will they take more time to get fully bright? My old meccatune HIDs took about 3 seconds to warm up, whereas my current kit only takes about a second.
11-03-2017, 02:04 AM #1
11-03-2017, 04:55 AM
DJ Wozza Mine was a cheap kit from China (ebay diane shop from what I can remember), seems to work fine for me Smile
So they get to full brightness quite quick then? Maybe I'll just go that route then, thanks Woz Smile
11-03-2017, 04:55 AM #2
11-03-2017, 06:25 AM
DJ Wozza About the same as dipped, but when you flash main beam people do know I'm letting them out so you should be ok ?
Good point, guess if it wasn't working you'd know by now! :thumbup1:
11-03-2017, 06:25 AM #3
Y2KANJAR
11-03-2017, 07:29 AM
One of my HID beams not work....good knows why
[SIGPIC]SINGH[/SIGPIC]
Y2KANJAR
11-03-2017, 07:29 AM #4
11-03-2017, 08:18 AM
Y2KANJAR One of my HID beams not work....good knows why
Try swapping the bulbs to see if it's the bulb or the ballast to blame......
Also check connections and fuses.
11-03-2017, 08:18 AM #5
Y2KANJAR
11-03-2017, 08:45 AM
i will do, the other side did work, going for the mot, then when i got it work the other one stopped ...arrrrrrrrrr
Y2KANJAR
11-03-2017, 08:45 AM #6
19-03-2017, 06:12 AM
Y2KANJAR i will do, the other side did work, going for the mot, then when i got it work the other one stopped ...arrrrrrrrrr
I saw yours at the ace meet, didnt know how quick they would light up so never got a set, after seeing yours its not a problem and going to get another set for the beams:thumbup1:
19-03-2017, 06:12 AM #7
Views 715
19-04-2017, 01:56 PM
