JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security IS200 stereo.
IS200 stereo.
IS200 stereo.
Andy-R.
14-03-2017, 10:57 AM
I know the stereo's in the IS depend on the code on the front as to which cars they'll work in but what are the chances of a bottom loading stereo from a 2001 working in a 99? is it luck of the draw if you don't know your code or was something changed between the years hence the different codesHuh
Cheers.
[Image: Lf9Nl.jpg]
Andy-R.
14-03-2017, 10:57 AM #1
Cheers.
[Image: Lf9Nl.jpg]
15-03-2017, 01:07 AM
I think it can be made to work but it's not plug and play as the plugs on the back are different I believe.
15-03-2017, 01:07 AM #2
kam05
15-03-2017, 01:20 AM
Plugs are different, you may have have splice up the loom in your car.
kam05
15-03-2017, 01:20 AM #3
15-03-2017, 01:55 AM
My 2005 one went into a 99 one all the guy did was chop off the 99 plugs and attach 2005 ones. Even the sat nav worked.
15-03-2017, 01:55 AM #4
Andy-R.
15-03-2017, 03:21 AM
Ah right cheers.
[Image: Lf9Nl.jpg]
Andy-R.
15-03-2017, 03:21 AM #5
Ah right cheers.
[Image: Lf9Nl.jpg]
Andy-R.
15-03-2017, 09:49 AM
Is it not just a case of matching up the colours then Wozza:blink:
[Image: Lf9Nl.jpg]
Andy-R.
15-03-2017, 09:49 AM #6
[Image: Lf9Nl.jpg]
15-03-2017, 10:40 AM
Here are the wiring diagrams, for SE/Sport (i.e. with external amp) :
Early cars
Minor change to early ones
Later cars
15-03-2017, 10:40 AM #7
Early cars
Later cars
Andy-R.
15-03-2017, 10:45 AM
Does anyone know the code for 99-2001 stereo's? Steve:wink:
[Image: Lf9Nl.jpg]
Andy-R.
15-03-2017, 10:45 AM #8
[Image: Lf9Nl.jpg]
15-03-2017, 10:53 AM
Andy-R. Does anyone know the code for 99-2001 stereo's? Steve:wink:
You mean the 5-digit code on the front ? I think there's more than one in that time period though. Mine is a 99 car and had a 13902 bottom-loader.
What do you want the code for ? Sorry, I might be misunderstanding.
15-03-2017, 10:53 AM #9
Andy-R.
15-03-2017, 10:59 AM
When mine broke ERR3 I took it somewhere for them to source a ISO lead for it but they weren't available then I found out about the by-pass cable so I got a replacement Sony unit and by-pass cable but never went back for the OEM unit, now I want to put an OEM one back in my car if I can so wanted to know the code for that year but if there's more than one it makes more difficult:Sulk: hope that clears it up
Thanks Steve
[Image: Lf9Nl.jpg]
Andy-R.
15-03-2017, 10:59 AM #10
Thanks Steve
[Image: Lf9Nl.jpg]
Views 662
30-09-2022, 11:42 AM
Replies 88
Views 19,644
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,422
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 708
28-09-2019, 08:22 AM
Views 419
17-09-2019, 11:52 AM
Views 741
12-07-2019, 10:36 PM
