JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Uneven height
Uneven height
Uneven height
icemahn
14-03-2018, 06:37 PM
I had my lex lowered by 40mm using sport coil springs. Before that, the back end was higher.After changing springs the front really looks good but the back is still slightly higher. I want it to look level, is there any adjustment that will do that?
Mazda CX7. 2.3 Turbo MPS. Corksport air intake. Turbo Smart dual port.
icemahn
14-03-2018, 06:37 PM #1
14-03-2018, 06:40 PM
With lowering springs, you're stuck with whatever height they are set at. Though bear in mind they will normally settle somewhat after installation. So if that lowering is new, put some heavy stuff in the boot (full tank of fuel will help) and give it a chance to settle a bit.
In theory you can cut down springs but most people would say that's rather dangerous and not recommended at all.
Another option I guess would be to source a set of rear springs that do have the height that you're after ?
Other than that, coilovers give you a full range of height adjustment so you can set the exact height yourself, but then you're talking a lot more money.
14-03-2018, 06:40 PM #2
icemahn
14-03-2018, 06:46 PM
Thanks Steve. I'll let it hit a few bumps and see if it settles.
icemahn
14-03-2018, 06:46 PM #3
Andy-R.
15-03-2018, 04:36 PM
I had mine done and it's taken a while but the rear has settled to a similar level to the front, can depend on where your parked when looking at it aswell though mate.
[Image: Lf9Nl.jpg]
Andy-R.
15-03-2018, 04:36 PM #4
[Image: Lf9Nl.jpg]
