JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza IS200 Wings diffrent models ?
ibby
19-03-2018, 06:27 AM
Hello guys is their a diffrence between wing types on an is200 99 reg when comprared to a 2009 ?
ibby
19-03-2018, 06:27 AM #1
19-03-2018, 06:29 AM
er yes i assume there would be, as there completely different cars
19-03-2018, 06:29 AM #2
19-03-2018, 06:34 AM
Do you mean between early (e.g. 99) IS200s and later ones ?
The only difference is if you have factory HIDs (e.g. IS200 LE or IS300), they've got a slightly different front wing. Otherwise it's the same.
You do mean the fender/wing, right ? Not rear spoiler I presume ?
19-03-2018, 06:34 AM #3
ibby
19-03-2018, 06:43 AM
yep
Fender theirs two on ebay that have been repaired @ 25£ but they are from a 2009 car
ibby
19-03-2018, 06:43 AM #4
yep
ibby Fender theirs two on ebay that have been repaired @ 25£ but they are from a 2009 car
So that's not an IS200 then, either IS220 or IS250 ?
19-03-2018, 06:43 AM #5
19-03-2018, 06:48 AM
I think it's an error in the ad, probably from an IS220/250. Contact the seller and ask.
19-03-2018, 06:48 AM #7
ibby
19-03-2018, 06:51 AM
The shape of the wing tells me they are from an is200.
But if you look at the inner edge of the wing its mounted diffrent.
ibby
19-03-2018, 06:51 AM #8
19-03-2018, 06:52 AM
The only difference for IS200 wings is for the factory HID models, so around the headlight it will be a bit different.
19-03-2018, 06:52 AM #9
19-03-2018, 06:54 AM
They look like is250/220 wings as they have no holes for the side indicator lenses?
19-03-2018, 06:54 AM #10
Views 799
12-12-2024, 07:55 PM
Views 874
08-11-2024, 09:35 AM
Last Post by Dinho
Views 1,835
06-11-2023, 07:38 AM
Views 3,953
02-11-2023, 04:43 PM
Views 651
06-08-2023, 05:47 PM
Last Post by Brad92
Replies 38
Views 3,420
23-02-2023, 07:09 PM
Views 671
18-10-2022, 07:53 AM
Views 1,048
03-09-2022, 04:53 PM
Views 797
29-08-2022, 03:48 PM
Replies 35
Views 9,829
04-08-2022, 10:23 AM
Last Post by cjoseph
