JapCarForum Cars, Cars, Cars! Wheels & Tyres What type of wheel nuts on IS200 rims?
Fozzy
22-03-2017, 12:48 PM
Simple enough. Do they use tapered wheel nuts, or the flat type wheel nuts?
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
22-03-2017, 12:48 PM #1
22-03-2017, 12:52 PM
Flat type matey iirc :biggrin:
22-03-2017, 12:52 PM #2
Fozzy
22-03-2017, 01:00 PM
Thats no good, guess i need to buy some wheel nuts as well then
Fozzy
22-03-2017, 01:00 PM #3
22-03-2017, 01:06 PM
These are the oem nuts mate, CLICK ME?
22-03-2017, 01:06 PM #4
Fozzy
23-03-2017, 12:16 AM
Cheers mate
Fozzy
23-03-2017, 12:16 AM #5
Cheers mate
Fozzy
24-03-2017, 07:44 AM
Top man. I have ordered some Standard toyota nuts, which are the same as the is200 and the rev 5 front wheel nuts. Also got some locking nuts as well. As i am fitting is200 rims it should work out ok.
Just a thought though, i am fitting 20mm spacers to the rear. Will i need to cut down the studs for the wheel to fit flush without fouling on the ends of the studs?
Fozzy
24-03-2017, 07:44 AM #7
24-03-2017, 07:47 AM
Do you mean the studs in the spacers or the studs in the hub? The studs in the hub should disappear into the wheels, a lot of rims the gap between stud holes isn't solid. If the inside wheel face is solid then yes you'll need to trim them, providing they are not dwarfed by the spacers!
For example this wheel has gaps on the inside face that the protruding studs would fit into:
[Image: rim4a.jpg]
24-03-2017, 07:47 AM #8
[Image: rim4a.jpg]
Fozzy
24-03-2017, 07:50 AM
Yeah the is200 rims are solid. They do have small holes drilled between the stud holes, but they aren't anywhere near large enough for the studd to sit into. I guess i will have to just wait and see when the spacers turn up
Fozzy
24-03-2017, 07:50 AM #9
Views 402
01-03-2023, 07:03 AM
Views 1,338
30-05-2022, 09:41 AM
Last Post by Tosh21
Views 1,425
20-08-2021, 11:21 PM
Last Post by reganlives
Views 1,149
27-07-2021, 08:37 AM
Last Post by leesw20
Views 631
15-03-2021, 05:14 AM
Last Post by Morango
Views 1,065
14-03-2021, 05:55 AM
Last Post by kaykay
Views 886
19-10-2020, 02:31 PM
Last Post by Chris0121
