JapCarForum Cars, Cars, Cars! General Car Maintenance Diff Oil
Diff Oil
Diff Oil
29-03-2017, 01:47 AM
Is it better to stick to OEM oil on an IS200 or is there anything better that the masses use....should i also get new fill/drain plugs & washers?
Edited 10-05-2010, 11:57 AM by SHAHZ.
29-03-2017, 01:47 AM #1
29-03-2017, 02:21 AM
On an IS200 you mean ?
Don't think there's an OEM oil as such, just use what the spec requires, which is gear oil API GL-5 SAE90 for temps of down to minus 18 degrees C. Fully synthetic is what is normally used for that.
Edit - something like this.
Edited 10-05-2010, 11:58 AM by steviewevie.
29-03-2017, 02:21 AM #2
29-03-2017, 02:26 AM
steviewevie On an IS200 you mean ?
:Fish: just edited the original post Big Grin
I meant in terms of Toyota oil or any other brand.....cool will just add to my opie order
29-03-2017, 02:26 AM #3
29-03-2017, 02:32 AM
Different garages probably use different brands anyway, I wouldn't worry about that.
29-03-2017, 02:32 AM #4
