JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza What is the differential ratio of an IS200?
02-04-2017, 10:16 AM
Does anyone know what is the OEM differential ratio for a manual Lexus IS200? Is it 3.909?
02-04-2017, 10:16 AM #1
Fozzy
02-04-2017, 10:23 AM
Sounds about right. The sports had the higher ratio
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
02-04-2017, 10:23 AM #2
02-04-2017, 10:35 AM
Hurricane Sounds about right. The sports had the higher ratio
Did the sports have 4.100?
02-04-2017, 10:35 AM #3
Fozzy
02-04-2017, 10:38 AM
Im pretty sure they did. We need Bandit, he would definately know
Fozzy
02-04-2017, 10:38 AM #4
02-04-2017, 10:48 AM
Hurricane Im pretty sure they did. We need Bandit, he would definately know
Yes we need his help Big Grin
02-04-2017, 10:48 AM #5
02-04-2017, 10:54 AM
It didnt.
All Manual IS200's have a ration of 3.909, the autos 4.1
The Altezza has one of 4.1 as well auto and manual
02-04-2017, 10:54 AM #6
It didnt.
02-04-2017, 10:58 AM
Sparkystav It didnt.
Thanks Stav for the info. So I suppose using an Altezza crown on an IS200 the acceleration will be better and the loss of top speed will be small.
02-04-2017, 10:58 AM #7
02-04-2017, 10:59 AM
Yeah if the Sport didn't have the same diff ratio as the S/SE, then it would have a lower/higher top speed and acceleration. Which it doesn't.
You can get the TRD diff to change the final drive ratio, which will speed up your 0-60. But it will lower your top speed, and make more noise and use more petrol (because you'll be doing more revs than before for the same speed).
02-04-2017, 10:59 AM #8
02-04-2017, 11:02 AM
steviewevie Yeah if the Sport didn't have the same diff ratio as the S/SE, then it would have a lower/higher top speed and acceleration. Which it doesn't.
Yes you are correct mate. Do you know by chance what is the loss of top speed? 10miles or more? Also what is the difference in revs at the same speed? 500rpm or more?
02-04-2017, 11:02 AM #9
02-04-2017, 12:52 PM
dimis Yes you are correct mate. Do you know by chance what is the loss of top speed? 10miles or more? Also what is the difference in revs at the same speed? 500rpm or more?
It depends which ratio you go for in the diff, I think there have been a few different ones on Altezzas, it's more complicated than the IS200. If you were going from 3.909 to 4.1 then that's around 4.9% difference, so I think you'd lose 4.9% off your top speed, which is about 6.5mph I think. And your revs would be 4.9% higher for the same speed. I think that's how it would work.
02-04-2017, 12:52 PM #10
Views 329
13-12-2023, 02:06 PM
Views 470
09-11-2023, 03:46 AM
Last Post by Dinho
Views 700
06-11-2022, 01:49 AM
Views 1,186
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,148
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 459
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,723
04-08-2021, 04:34 AM
Last Post by cjoseph
