JapCarForum Trade Area Trade Archive Wanted Archive dry sump pump
dry sump pump
dry sump pump
warpspeed
07-04-2017, 06:08 PM
As above, anybody got one for sale?
no sillyt prices mind! :laugh:
warpspeed
07-04-2017, 06:08 PM #1
08-04-2017, 01:14 PM
as in a pump setup for a dry sump? expensive bit of kit surely?
08-04-2017, 01:14 PM #2
warpspeed
08-04-2017, 03:36 PM
yeah but it's just the pump i need, or pumps! i'm just looking for one just now but will need another one or two as i get nearer to completion on other projects. I'm after a two stage pump and the reason i'm not after a complete kit is that i will be fabricating the sump etc myself for a custom installation.
warpspeed
08-04-2017, 03:36 PM #3
09-04-2017, 06:25 AM
Why a dry sump, there are other ways of getting constant oil pressure without the cost etc.
09-04-2017, 06:25 AM #4
warpspeed
09-04-2017, 11:07 AM
more power to be had with a dry sump Confusedneaky2:
warpspeed
09-04-2017, 11:07 AM #5
10-04-2017, 12:45 AM
Yea, that figures!!
A lot of the lotus track cars use the Accusump device, that stops oil starvation at high G's.
http://www.accusump.com
10-04-2017, 12:45 AM #6
Yea, that figures!!
warpspeed
10-04-2017, 05:02 AM
if you remove the oil from the sump as quickly as poss and have a scraper and windage tray fitted the crank doesn't have to travel through the oil mist, i expect the gain back at least 20hp with the engine spec i'm using. i already have an accusump for my road/track car and it works great, just doesn't help with the power to weight ratio.
warpspeed
10-04-2017, 05:02 AM #7
10-04-2017, 06:48 AM
Thats a whole lot of BHP gained, I had thought it was because a dry sump eliminates the oil starvation issues when in high "G" corners, I am pleased to learn something new!!
10-04-2017, 06:48 AM #8
Chri5
10-04-2017, 07:57 AM
I have also learnt something new Wink
Chri5
10-04-2017, 07:57 AM #9
warpspeed
10-04-2017, 09:56 AM
2tongues Thats a whole lot of BHP gained, I had thought it was because a dry sump eliminates the oil starvation issues when in high "G" corners, I am pleased to learn something new!!
Yep, you're spot on about it solving starvation and if my pulsar was just going to be a road car never to see a track or the 'ring then an accusump is perfect and i'm really happy with the one on my sunny. I'm still tempted to use an accusump on the pulsar alongside the dry sump as the one big advantage over a dry sump is being able to pre-oil the engine before start up.
warpspeed
10-04-2017, 09:56 AM #10
Views 180
17-05-2019, 02:34 AM
