JapCarForum Cars, Cars, Cars! General Car Maintenance help !!!!!!!
help !!!!!!!
help !!!!!!!
h11exx
08-04-2017, 10:38 AM
help guys, ok switched air con on and engine management light has come on help me. is this a bad sign ......
h11exx
08-04-2017, 10:38 AM #1
08-04-2017, 10:44 AM
You really need to get the code read. Can you get someone to plug in an OBD-II reader ? Then if you get the code, we can see what the problem might be.
It sounds odd that the aircon seems to be linked with the light coming on. Could just be a coincidence. Or maybe a voltage drop caused by the aircon causing another glitch ?
Get the code (will be something like Pxxxx) where xxxxx is four digits, and we can go from there Smile
08-04-2017, 10:44 AM #2
Chri5
08-04-2017, 11:09 AM
Does it go off when you switch aircon off???
Wish I had aircon lol
Chri5
08-04-2017, 11:09 AM #3
h11exx
08-04-2017, 11:13 AM
no it doesnt its really wierd. it only happened whn the air con was switched on. god how annoying
h11exx
08-04-2017, 11:13 AM #4
08-04-2017, 11:34 AM
Anyhing weird happening with the way the car drives, e.g. loss of power etc ?
08-04-2017, 11:34 AM #5
h11exx
08-04-2017, 11:50 AM
nope running fine. apart from when the steering is turned revs go up
h11exx
08-04-2017, 11:50 AM #6
Chri5
08-04-2017, 11:53 AM
but it does that so it can turn the pump so thats normal
Chri5
08-04-2017, 11:53 AM #7
h11exx
08-04-2017, 12:27 PM
i need ideas boys pleassssss lol
h11exx
08-04-2017, 12:27 PM #8
08-04-2017, 01:26 PM
Broken :Chair:
08-04-2017, 01:26 PM #9
Broken :Chair:
h11exx
08-04-2017, 01:59 PM
thats no helpppppp plsssss help
h11exx
08-04-2017, 01:59 PM #10
