mmHg to psi or bar
mmHg to psi or bar
Just been out in my car.
And as things seem to be ok I'm putting my foot down a little bit more each day
but today was the 1st time I've properly looked at the boost setting on the apexi commander as this shows the highest boost recorded etc.
Just come back in and it's showing 0.85mmhg
in terms of psi or bar does anybody know how to convert this???
Thanx in advance
Cheers oli
but I've already looked at 1 of these sites an come up with same result.
So apparently I'm running at 1.4psi which can't be right.
Whats your boost gauge been showing?
is the boost controlled by the apexi? is the pipe kinked?
Does the apexi change its map for the boost level? (on the link its just a knob to change boost so its boost dependant fuelling, is the apexi just a set map?)
I didn't see the gauge tbh.
The boost is controlled by Aem electronic bc
so I'm presuming the apexi just shows the outcome???
I don't know if it changes the fueling to suit tho???
has the commander ever shown the boost? is it even connected to the BC then?
It only shows boost when I ask it to tbh.
I don't know if it connects to bc or not.
I just presumed it was acting as a gauge???
So am I best ignoring that bit???
dunno mate, depends how its all been wired/setup
I'LL ask phil an see if he knows
no point presuming things in case it's wrong lol
Chri5 Cheers oli
Chri5 Cheers oli
