JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza help high oil pressure
15-04-2017, 07:24 AM
HI
I seem to be having problems again with high oil pressure!! Confusedad: when started from cold in the mornings or after work i start the car and my oil pressure gauge starts off by sitting at oround 50 to 60psi, i normally leave the engine on tick over for a minute or 2 before heading off and the oil pressure starts to drop down to 40-50psi as i start my journey. but then 5 minutes or so later down the road the oil pressure starts to go off the gauge hitting the 100psi mark!! and the engine starts to feel very sluggish as if something is blocking the power. so i back off the peddle and it then drops back to about 70-80psi but if i have to reaccelerate from junctions the psi goes right back up again till i back off and it drops again to the 70psi. but then after about another 5 minutes of very gentle driving the oil pressure returns to normal sitting at 30 to 40 psi during normal driving and going up to 60ish on acceleration and about 20-30psi sat in traffic. can someone please help i have asked lexus reading twice about this and they say there is nothing wrong, there are no warning lights indicating any problems. i dont want this to get expensive or blowing up on me!!!
what do i do??? can someone please help me.
i have ac autotechnics gauges if that helps
i have also tryed resetting ecu by pulling fuses and disco'ing the battery.
thanks
dean
15-04-2017, 07:24 AM #1
HI
thanks
dean
15-04-2017, 07:53 AM
What oil do you use on your car Dino?
This normal means two things either a problem with your oil pump or a problem in the engine
First thing If the oil level is where it should be you need to check the oil pressure with a manually operated pressure gauge these can be found at a local Garage.
15-04-2017, 07:53 AM #2
15-04-2017, 08:11 AM
it was serviced only last month in april at lexus reading so what ever oil they are using mate. the oil level seems to be sitting just above the divet so it looks like they over filled it maybe? Bar stewards need to get a job in a pub not a garage!!:cursing: ok so looks like im going to have an oil change at the weekend! cant believe i hadnt noticed that it was sitting higher than it should be cos im sure it wasnt at that level last time i checked it cos we were looking at it at japshow. how many litres am i going to need as ive not done an oil change by meself.
15-04-2017, 08:11 AM #3
15-04-2017, 08:22 AM
5.5 LITRE will do you Opie will supply a good oil for you if your interested and they give a good service
At the moment there offering 5 litre plus a free 1 litre
The oil should be 5w-30 Engine Oil or equivalent.
15-04-2017, 08:22 AM #4
15-04-2017, 08:31 AM
yeah just looking at opie now mate, i wont need to change the oil filter will i? or does it need replacing as well what would you recomend as its only been on there a month if they replaced the old one?
whats better fuchs or castrol or something else? i hate shopping when i got a choice lol. can never make my mind up
15-04-2017, 08:31 AM #5
15-04-2017, 08:36 AM
Dino pick a oil and stay with that brand each time you change it.
Oil filter are really cheap so it worth doing this as well, but it not necessary.
15-04-2017, 08:36 AM #6
15-04-2017, 08:41 AM
Lexusboy Dino pick a oil and stay with that brand each time you change it.
cool i'll have a better read on oils when i get home and try to get to a deciscion. how easy is it to replace the filter as im sure ive heard people saying its not the easiest thing in the world to get to cos of its position.
15-04-2017, 08:41 AM #7
15-04-2017, 08:43 AM
As its only been on there a around four month it should be ok the garage should of done it up hand tight only...
15-04-2017, 08:43 AM #8
15-04-2017, 09:11 AM
Your oil pressure should go up and down with revs mate as its run off the engine, but does sound a little odd
15-04-2017, 09:11 AM #9
15-04-2017, 09:45 AM
It does sound strange. I don't think just changing the oil is going to fix that, I doubt that being very slightly overfilled (it's not massively over-filled is it ?) is the cause.
15-04-2017, 09:45 AM #10
Views 277
22-02-2020, 03:31 AM
Views 317
27-05-2016, 03:40 AM
Last Post by reganlives
