Try from the top of the engine with a ring spanner with a bendy head, lack of room is a pain!!
Or drop the gearbox a bit and then use a long extension with universal joint, again a pain!!!!
whats the best way to drop the gear box undo the shaft from the back of the box then undo the gear box mount do i need to undo engine mounts to get it to tilt more
