JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help with ssqv
Help with ssqv
Help with ssqv
micromarc
07-05-2017, 05:23 PM
So guys the moment finally came tonight to fire up the car with the lysholm charger all good except my dump valve ain't working properly.
It's like there's not enough vaccum pressure to let it open, as we tested it using a screw driver to hold it open and worked perfect.
Any ideas?
micromarc
07-05-2017, 05:23 PM #1
Any ideas?
Fozzy
08-05-2017, 07:35 AM
where have you got it plumbed into? Ideally the ssqv shouldn't be t'd off another line and should have its own dedicated line straight from the inlet plenum/manifold
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
08-05-2017, 07:35 AM #2
08-05-2017, 08:38 AM
Are these any good for using with the supercharger ??
And can you hear it above the noise of the induction kit ??
08-05-2017, 08:38 AM #3
08-05-2017, 08:51 AM
they do jack moley just sound good ye you can hear it matey....i have the ssqv one too.
08-05-2017, 08:51 AM #4
08-05-2017, 08:57 AM
I was not worried about them doing anything mate, just if you could hear it.
I thought you had a fake one , is that not the case
08-05-2017, 08:57 AM #5
08-05-2017, 09:09 AM
to be honest i dont know steve put up a post on how to tell if its fake.......well after stripping mine its not according to what was in the post....
spoke to a few people about this and the money i paid when its converted in to their money is a lot!!!
you wanting a sound clip??
Edited 19-06-2010, 06:45 PM by ormi.
08-05-2017, 09:09 AM #6
iano21
08-05-2017, 09:22 AM
well
i saw a lot of the fakes and none of them had the HKS badge on them on the top and also where the vacuum tube goes on, the steel pipe it is just straight no hump to stop pipe coming off where the fake ones did have a hump!! plus they had no coloured insert in them. just things i noticed about fakes ones. .
the fake ones here are about €140 where as the real ones are €240.
its very hard to get a vacuum line by itself without going to fierce rounds most people tee off the vacuum line coming off just under the butterfly on the throttle body you can see it on the side!!
ian
iano21
08-05-2017, 09:22 AM #7
well
ian
yes mate and a link to the seller , if you dont mind
08-05-2017, 09:22 AM #8
08-05-2017, 10:11 AM
What pressure are you running mate>?
Is it a HKS one? it wont be theres not enough vacuum, its prob that theres not enough pressure
08-05-2017, 10:11 AM #9
08-05-2017, 10:14 AM
heres a video with the ssqv dumping......
http://www.youtube.com/watch?v=yQqv1GK5D...a2cef0e5d5
second one showing the inside part working..
http://www.youtube.com/watch?v=TusyqmlEK...d107e79708
08-05-2017, 10:14 AM #10
