JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Wonky cambelt.
Wonky cambelt.
Wonky cambelt.
garyskisplym
08-05-2017, 10:06 AM
i heard a weird noise on start up the other day then drove to mates and could not hear it (Could just be hidden by other noises) on the move and i thought i was hearing thing, then my mate heard it when i picked him up and stated the car again
He seems to think it is a wonky cambelt, is there an easy way of checking this??
Also is it anything to worry about??
Just the car goes in bodyshop tuesday and im out the country from wednesday.
gary
garyskisplym
08-05-2017, 10:06 AM #1
gary
08-05-2017, 10:18 AM
em yes it is if it goes you'll be cheaper buying a new engine,remove the top cover on the front of the engine and have a look matey....
08-05-2017, 10:18 AM #2
08-05-2017, 10:19 AM
Yes mate, if the cambelt goes then this will knock the timing out of alignment, which will mean the pistons will be still going up and down and the valves will be open, bending the valves and/or conrods, and maybe indenting the pistons.
08-05-2017, 10:19 AM #3
garyskisplym
08-05-2017, 10:30 AM
i know if it slips will mess engine completely but what i ment is should cam belts just move??
So remove cover then start up and you should not see the belt move side to side.
Am i right??
garyskisplym
08-05-2017, 10:30 AM #4
Am i right??
garyskisplym
08-05-2017, 10:38 AM
is it common to get cambelt wobble on them??
as the garage changed mine when i brought it less then 3 months ago
garyskisplym
08-05-2017, 10:38 AM #5
Fozzy
08-05-2017, 03:45 PM
They can creep a little on the pulleys, but not by much. I would find it unlikely that it could move enough to cause a real problem. Do you know if the tensioners were changed at the same time as the belt.
To be honest without know what the noise is its difficult to tell, but as said above remover the small cambelt cover at the top and take a look.
If your still concerned, take it back to whovever fitted it and get them to take a look asap
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
08-05-2017, 03:45 PM #6
garyskisplym
10-05-2017, 01:58 AM
dont know if the tensioners were changed,
Going to maybe wip the cover off tonight to have a look.
garyskisplym
10-05-2017, 01:58 AM #7
Phil01
11-05-2017, 09:02 AM
Pay special attention for a loose tensioned belt, sounds like it may be slapping about and hitting lower belt covers, not so much of a wonky belt, more like a very loose push bike chain, be careful as it can jump the teeth on the pulley after the initial start due to the torque of the engine, ie, worse when starting
Phil01
11-05-2017, 09:02 AM #8
Phil01
11-05-2017, 11:14 PM
Did you get chance to pull the cover off and have a look last night??
Phil01
11-05-2017, 11:14 PM #9
garyskisplym
19-05-2017, 11:34 AM
hi people
just got bacl from holiday.
Have not had a change to do it yet.
I get the car back tomorrow evening so will wipe cover off them
garyskisplym
19-05-2017, 11:34 AM #10
hi people
