JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza is200 sport springs
is200 sport springs
is200 sport springs
garyskisplym
22-05-2017, 12:28 PM
Am i right in thinking at the is200 sprts sit slightly lower then other is200s??
I remember reading that preface lifts are 10mm lower and face lift are 15mm lower then standard.
Is this correct???
garyskisplym
22-05-2017, 12:28 PM #1
Is this correct???
garyskisplym
22-05-2017, 01:04 PM
Gord Yes correct mate :thumbup:
So if i find a face lift sport and change my springs for them my car will be 5mm lower and if i fit trd springs it will sit 20mm lower (TRD spring are 30mm lowering arnt they???)
garyskisplym
22-05-2017, 01:04 PM #2
23-05-2017, 01:04 AM
I'm not sure it's quite as simple as that - early SEs and Sports were much higher than later SEs and Sports.......I don't know what changed, but something did so really have no idea what will happen.
TTE springs are a 30mm drop, but again people with early cars (like Stevie) have seen a slightly bigger drop than 30mm.
23-05-2017, 01:04 AM #3
23-05-2017, 05:57 AM
garyskisplym So if i find a face lift sport and change my springs for them my car will be 5mm lower and if i fit trd springs it will sit 20mm lower (TRD spring are 30mm lowering arnt they???)
Yes mate tte springs are 30mm drop, but as Dean says your better of getting some aftermarket springs rather than sport ones
23-05-2017, 05:57 AM #4
garyskisplym
23-05-2017, 07:41 AM
Found a lexus is being broken but come back as not a sport.
Also does anyone have a before and after pic of there cars with trd kit???
may just save but and get a get of tein coilovers.
garyskisplym
23-05-2017, 07:41 AM #5
23-05-2017, 08:13 AM
Marsdendean ^^ Do coilovers lower the car if you get adjustable ones? I thought they just stiffen the suspension, and havn't asked the question, and im unsure!
Depends on the coilover I think, some do nothing, some are height adjustable, some can adjust damping Smile
23-05-2017, 08:13 AM #6
23-05-2017, 09:45 AM
Marsdendean are there ones that can do all 3.
Ideally i want to lower mine sometime in the future, and was going to by ARBS, but then decided i may need some dampening ones, for when i have weight in, so the springs dont compress too much
You can't do all 3 as one option was "do nothing" :tongue_smilie:
But yeah a lot of them can adjust height and damping, if you get the Teins with EDFC you can eve adjust the damping from the control unit inside the car but I don't think those ones are cheap.
23-05-2017, 09:45 AM #7
Andy-R.
23-05-2017, 10:27 AM
Mine was dropped 40mm I got the same springs Ormi had before he got coilovers, may be worth seeing if he's still got his old suspension with the lowerering springs fitted and if he's selling them.
Heres' mine before:[Image: th_SS852014.jpg]
[Image: th_SS850619.jpg]
After:
[Image: th_SS852051.jpg]
[Image: th_SS852213.jpg]
[Image: Lf9Nl.jpg]
Andy-R.
23-05-2017, 10:27 AM #8
After:
[Image: Lf9Nl.jpg]
Andy-R.
23-05-2017, 10:30 AM
Ahhhhhh done it again,where's the edit:
Before:
[Image: SS850619.jpg]
[Image: SS852014.jpg]
After:
[Image: SS852213.jpg]
[Image: SS852051.jpg]
[Image: Lf9Nl.jpg]
Andy-R.
23-05-2017, 10:30 AM #9
Before:
After:
[Image: Lf9Nl.jpg]
23-05-2017, 02:53 PM
Marsdendean ^ I wouldn't mind if i could do it from under the bonnet / in the boot. I would only want to set the height and hardness / soft once, and why can't they do nothing?? :Chair:
That way i would only need a set of coil overs & arbs
Lol, no what I meant was that a coilover can't be adjustable but also have fixed height & damping (i.e. do nothing) - it's one or the other!
But you're right, if you're thinking of getting coilovers don't bother with lowering springs.
@ Andy-R: The before pic looks higher than some 4x4s! :w00t:
23-05-2017, 02:53 PM #10
Views 411
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 904
06-11-2022, 01:49 AM
Views 3,042
02-11-2022, 10:55 AM
Views 369
06-08-2022, 11:58 AM
Last Post by Brad92
Views 326
14-03-2022, 09:45 AM
Last Post by VVT-Einstein
Replies 38
Views 1,592
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 457
03-09-2021, 07:29 PM
Last Post by Ratchet
Views 359
03-09-2021, 07:20 PM
