JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension front calliper refurb walkthough needed
26-05-2017, 04:49 AM
is there one on here yet as i cant seem to find one, i got my refurb kit through this morning, so as soon as i can find a walk through i will be attempting to rebuild them as the front right is squeeling like the devil on helium Sad
26-05-2017, 04:49 AM #1
26-05-2017, 04:50 AM
I took lots of pics when hurricane and I did mine I'll see if he can put a walkthrough together
26-05-2017, 04:50 AM #2
26-05-2017, 04:53 AM
thank you mate you a legend Smile i also might try and get my do-luck brake lines on at the same time Smile
26-05-2017, 04:53 AM #3
Fozzy
26-05-2017, 04:59 AM
Ill try and get one done for you ASAP matey
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
26-05-2017, 04:59 AM #4
26-05-2017, 05:02 AM
Hurricane pics are in my photobucket....
26-05-2017, 05:02 AM #5
Fozzy
pm me a link matey
Fozzy
26-05-2017, 05:02 AM #6
pm me a link matey
26-05-2017, 05:04 AM
cheers guys much appreciated Smile
26-05-2017, 05:04 AM #7
26-05-2017, 05:47 AM
slightly off topic here but i've been reading a few conflicting threads regarding is200 brake pad change, but do the clips for the pads go on the inside or outside of the disc? Also do they go at the front or back of the caliper?
26-05-2017, 05:47 AM #8
26-05-2017, 09:32 AM
Dan's talking about the clips that are attached to the back of 1 pad each side. Does the pad with this clip attached go on the inside or the outside of the caliper, and should the pad be oriented so that the clip is at the top or bottom of the caliper?
Helpfully on Dan's car the old pads had BOTH pads with clips on on the passenger side and the pads with no clips on on the driver's side :lol:
This is the clip in question, thanks to TommyH:
[Image: SNV33374.jpg]
26-05-2017, 09:32 AM #9
Views 365
18-04-2021, 02:49 PM
Last Post by Timbo
Views 593
14-10-2019, 10:02 AM
Views 276
20-07-2019, 01:32 AM
Last Post by jomo
Views 437
07-04-2019, 09:04 AM
Views 420
29-07-2017, 10:09 PM
Last Post by TimmyK
Views 540
17-01-2017, 12:44 AM
Views 328
05-01-2017, 04:09 AM
Last Post by Ally
Views 406
20-07-2016, 12:10 AM
Views 558
16-07-2016, 04:21 AM
Last Post by aaronabbott
