JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning HKS Silent High Power center section ??
01-06-2017, 07:20 AM
Well I used to have a full S/S exhaust, ( Blueflame ) but I sold it to Rabster and I changed mine to a HKS Silent High power .
Now the question I have is can I get the center section to make it a full system again.The blueflame one has a different size back box so the center section is made just for it .
01-06-2017, 07:20 AM #1
01-06-2017, 07:50 AM
You'd have to get one custom made mate i think
01-06-2017, 07:50 AM #2
01-06-2017, 07:52 AM
powerflow could be ideal
01-06-2017, 07:52 AM #3
01-06-2017, 07:59 AM
i've been searching for like a year and a half as i got the backbox and like you looking for the centre section but had no luck in finding the hks section part Sad closest ive found is the megan racing and obx downpipes on ebay but delivery is the same price as the item making it close on £200!! so going to have a look at getting a custom pipe knocked up and see how much cheaper it will be, i might try and use MIJ as they did me a good setup on my mondeo.
01-06-2017, 07:59 AM #4
01-06-2017, 08:36 AM
OK might just have to take the center section off when the car is garaged up in winter time and make one , would I just need the pipe and flanges or is there sensors aswell
01-06-2017, 08:36 AM #5
01-06-2017, 09:03 AM
you could make centre hole for the sensor if you wanted to continue using the o2 sensor or you could bypass the sensor by wiring in an oxygen simulater which is 4 wires costs about 10 or 20ish quids and that cancels the cel light on the dash
01-06-2017, 09:03 AM #6
01-06-2017, 09:56 AM
Ok thats my winter project !!
01-06-2017, 09:56 AM #7
02-06-2017, 11:57 AM
come on moley....cut the center box out and just weld in a bit of straight pipe will take you two mins...mesure the outer diameter find a bit of pipe slightly bigger cut out the center section slide on the pipe and weld job done...also no sensors near the centerbox...
02-06-2017, 11:57 AM #8
02-06-2017, 12:43 PM
No no mate , I want it to be all S/S and not a botch job like you are saying mate
02-06-2017, 12:43 PM #9
02-06-2017, 01:00 PM
remove the center section mesure from end to end make the pipe up then cut the flanges off the old one and weld them on...
but to be honest a full stainless center section will be no diff to the centerbox cut out and a pipe welded in correctly....if you look under the car you will find theirs no corrosion or hardly any on the center pipe..
02-06-2017, 01:00 PM #10
Replies 37
Views 2,042
12-03-2020, 10:01 AM
Last Post by posty
Views 419
13-03-2019, 01:23 PM
Last Post by S
Views 883
19-04-2017, 01:56 PM
Views 1,392
05-04-2017, 10:28 AM
Last Post by supratruck
Replies 35
Views 1,721
16-02-2017, 03:57 AM
Last Post by Chri5
