Speed cam
Speed cam
Hi guys, can any one tell me how fast you can go pass a cam before it will flash ? 31 32 33 and so on, how much do they give you before it flash,s ??
aido I think the rule used to be over + 10% + 2mph, ie over 35 in a 30, although I did read someplaces have started lowering that but not sure, that seems about right to take account for any speedos that aren't calibrated right?
My mate got a ticket for going 71 in a 60
This info is taken off the website...
That enforcement should begin following the ten percent plus two mph rule Eg 50 mph + 10% (5) + m2 mph = 57.
Thata driver cannot be dealt with a Conditional Offer of Fixed Penalty if the speeds reach the levels indicated in the last column
Link to sitehttp://www.speedcamerasinfo.co.uk/2.html
i got done for 34 in a 30, i was convinced it was a dual carrigway and was 40 !
I got 3 points for doing 40 in a 30 zone. It was a real bummer since it was a road where the speed limit changed several times, and I was convinced I was still in the 40mph bit. My fault though, at the end of the day.
Your speedo will be reading approx 10% over anyway, so if it said 31 or 32 then you will have only been doing abour 28 or 29mph.
steviewevie I got 3 points for doing 40 in a 30 zone. It was a real bummer since it was a road where the speed limit changed several times, and I was convinced I was still in the 40mph bit. My fault though, at the end of the day.
