JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension IS Camber/Stance
IS Camber/Stance
IS Camber/Stance
Pages (3): 1 2 3 Next
TimmyK
12-07-2017, 02:14 AM
http://www.stanceiseverything.com/wp-con..._is300.jpg
Can this stance be acheived without the aid of aftermarket top mounts and coil overs?
All the car will have is lowering springs
Car 1 - 02 Lexus IS200 SE Strathcaron Blue, Sport Grille, TTE Lowering Springs (to be fitted), K&N Panel Filter, 6500K XENON Headlight Main & Dipped Bulbs, Xenon Sidelights, 17" Gunmetal Powder Coated Alloys, Front Grooved Discs and Mintex Pads
Car 2 - 73 Hillman Imp AKA Hilda, Aquarious Blue, work in progress!
TimmyK
12-07-2017, 02:14 AM #1
12-07-2017, 02:22 AM
You could ask WIM (Wheels in Motion)this question you can either call Tony Bones or try pm him.
12-07-2017, 02:22 AM #2
TimmyK
12-07-2017, 02:30 AM
ok cheers asked the question
TimmyK
12-07-2017, 02:30 AM #3
12-07-2017, 02:31 AM
You wont get the car that low on springs, you will also need some serious work done on the arches to get wheels with that kind of offset on there
12-07-2017, 02:31 AM #4
TimmyK
12-07-2017, 02:34 AM
Not after the lowness as such just the camber as that stance looks so mean and aggressive just asking the question can it be done on springs alone? I guess the case is not
TimmyK
12-07-2017, 02:34 AM #5
12-07-2017, 02:51 AM
would of thought you would need the adjustable top arms at the very least mate, theres not much adjustments that can be done with standard equipment, but Tony at Wim will give you the ultimate answer.
12-07-2017, 02:51 AM #6
23-07-2017, 12:06 PM
yes you can get the wheels to sit like that mate...
[Image: mycaratsmc1.jpg]
i still have plenty of adjustment
23-07-2017, 12:06 PM #7
TimmyK
27-07-2017, 02:32 AM
ormi yes you can get the wheels to sit like that mate...
how did you manage it?
TimmyK
27-07-2017, 02:32 AM #8
99
27-07-2017, 11:57 AM
The position has been engineered. To achieve this you need adjustable rear camber arms ( drift territory ) and for the front adjustable upper wishbone spherical ball joints ( same as listed for the IS220/ 250 ) by Eibach.
Depending on the wheel off-set you may need to roll or flair the rear arches but the camber tilt may belay this depending on the coil rate on bump.
Whatever route you take this "look" is sacrificial toward tyre life, so if you go for the wide, low as grannies nipples look you will pay for the privilege in rubber...... Be wise.
wheels-inmotion
27-07-2017, 11:57 AM #9
27-07-2017, 01:25 PM
wheels-inmotion for the wide, low as grannies nipples look you will pay for the privilege in rubber...... Be wise.
That has to be one of the best quotes I've heard in a long time :lol::lol::lol:
27-07-2017, 01:25 PM #10
Replies 26
Views 1,177
27-12-2018, 01:35 PM
Last Post by James S
