JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Day time running lights
Pages (3): 1 2 3 Next
jomo
13-07-2017, 03:41 PM
Ok the misses has made me buy her a set of day time running leds for her Toyota Celica, but as she hardily goes out at night in the car she wants them to come on with the ignition!
So my question is where do i find a live feed under the bonnet to run the lights from that come on with when the engine is started, so i don't have to run a switch inside the car to turn them on/off?
Gonna feed mine into the side lights so that's straight forward, I've also got inline fuse holders with 500ma quick blow fuses to keep everything nice and safe.:thumbup1::thumbup1:
One for Stave me thinks......
jomo
13-07-2017, 03:41 PM #1
14-07-2017, 12:22 AM
You could use the ignition feed in the ecu or if you wanted to be realy flash you could use a light dependant resistor ....
14-07-2017, 12:22 AM #2
Phil01
14-07-2017, 05:22 AM
light dependant resistor ,,,,,, I want one!, what ever it is :drool:
Phil01
14-07-2017, 05:22 AM #3
14-07-2017, 05:34 AM
Is200's already have LDR's though, for turning on headlights when set to auto?
14-07-2017, 05:34 AM #4
14-07-2017, 08:19 AM
Your best bet as Rabster says is using a switched live in the ECU,
use the owners manual online to identify one.
No point using an LDR if she wants them on in the day
14-07-2017, 08:19 AM #5
14-07-2017, 08:21 AM
stav you can get ldrs which will turn off in the night too
14-07-2017, 08:21 AM #6
14-07-2017, 09:34 AM
why would you want to?>
14-07-2017, 09:34 AM #7
14-07-2017, 09:41 AM
Yes dean, by the instrument cluster, well above it.
14-07-2017, 09:41 AM #8
14-07-2017, 10:10 AM
Marsdendean Can you paint the LDR's black to make them run all the time? And the IS200 are at the bottom of the windscreen arnt they?
theres only one, the other measure the sun light for the air con i believe.
why would you want to though?
14-07-2017, 10:10 AM #9
14-07-2017, 10:15 AM
Why would you want to what Stav, paint them black, or have day runners?
14-07-2017, 10:15 AM #10
Replies 32
Views 2,037
09-11-2019, 06:50 AM
Last Post by Predator
Views 749
14-10-2018, 09:50 AM
Last Post by jomo
Views 644
29-07-2017, 04:15 AM
Last Post by Duv
Views 1,350
30-01-2017, 11:10 AM
Last Post by abactus
Views 1,467
12-07-2016, 02:14 AM
Last Post by N2KHL
