JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza programming new Key Fob help!!!!
Pages (4): 1 2 3 4 Next
wahidhussain
05-08-2017, 11:07 AM
hi guys
i have tryed all in the Reprogramming Key Fob thread but failed
my car is a may03 reg se when am on step 5 in the 2ND VERSION SLIGHTLY DIFFERENT the light continuous to flash i waited for more than 2 mins
still no luck
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and
remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
For 2002+ Toyota, Lexus
Add Duplicate Key
Requires one working Toyota/Lexus Master Key.
1. Make sure all doors and windows are closed.
2. Insert Master key into the ignition cylinder.
3. Cycle the ignition cylinder from On to OFF five times.
4. Open and close the “driver side” door 6 times.
5. Remove the Master Key and insert the new duplicates key.
6. TURN THE IGNITION CYLINDER ON.
7. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
To program the immobilizer bit of your new key:
First, have your new key cut. Then:
For 1998+ Toyota, Lexus
Add Duplicate Key
remove key.
To make your Lexus remember your key's wireless signal:
For the remote part in drivers seat WITH DOOR OPEN.
Start with door unlocked.
1. Put master key in ignition, turn to on, then back off and remove.
2. Using the lock/unlock button on drivers door. press lock.. then unlock 5 times.(lock,unlock,lock,unlock,lock,unlock,lock,un lock,lock,unlock)
3. Close drivers door, open drivers door.
4. Perform lock/unlock procedure again. DO NOT close and open drivers door. Just the lock/unlock procedure again.
5. Insert NEW key in to ignition and turn to on, then back off and remove.(at this point the doors should lock and unlock by themselves ONCE)
6. Now press both lock and unlock buttons on REMOTE. Release after about 1.5 seconds.
7. Now press just the lock button on remote.
once you press the lock button, the car should lock and unlock ONCE, if it lock unlocked TWICE you messed up somewhere.
8. Now open and close the drivers door a couple times to close programming.
if you did it right, remote will now work."
wahid
wahidhussain
05-08-2017, 11:07 AM #1
hi guys
still no luck
remove key.
Add Duplicate Key
Add Duplicate Key
remove key.
wahid
Fry-Up
05-08-2017, 11:15 AM
i'm pretty sure that when I programmed mine I didn't press the accel and brake together, I followed a guide from MyIS website I think
Fry-Up
05-08-2017, 11:15 AM #2
wahidhussain
05-08-2017, 12:08 PM
Fry-Up i'm pretty sure that when I programmed mine I didn't press the accel and brake together, I followed a guide from MyIS website I think
i just tryed that aswell mate no luck Sad
wahidhussain
05-08-2017, 12:08 PM #3
JeffMcC
05-08-2017, 12:19 PM
Im there right with you mate. Had ago at all combs still no luck so this time im bringing my new key with me to the ace meet and someone else can try for me. Blush
JeffMcC
05-08-2017, 12:19 PM #4
Fry-Up
05-08-2017, 12:23 PM
I wish I could help more, i've done 2 keys on my current IS and 1 on my old one, but i'm goin back ages and can't remember which steps I followed
Fry-Up
05-08-2017, 12:23 PM #5
Saraj
05-08-2017, 12:40 PM
i tried the above on my ex-is200 and it worked you got to try about 20 times like i did untill you get it perfect
Saraj
05-08-2017, 12:40 PM #6
wahidhussain
05-08-2017, 02:20 PM
hi
thanks guys
has anyone programmed a key 3 button from ebay on to a 03reg is?
thanks
wahidhussain
05-08-2017, 02:20 PM #7
hi
thanks guys
thanks
05-08-2017, 11:06 PM
i haven't programmed any keys but if you can get to the ace cafe meet there are people going that could possibly help....
or even japshow finale....
05-08-2017, 11:06 PM #8
captain
06-08-2017, 01:36 AM
I have programmed a key from ebay on a 04 IS200. I found the guide on MyIS site bur I don't remember which one worked finally. Just try them all with no harry and one will work.
I will try to find the papers from the guide that worked for me and I will post it later.
captain
06-08-2017, 01:36 AM #9
wahidhussain
06-08-2017, 02:32 AM
Rabster i haven't programmed any keys but if you can get to the ace cafe meet there are people going that could possibly help....
i think i wont have time for the meets mate i would try tro
thanks
captain I have programmed a key from ebay on a 04 IS200. I found the guide on MyIS site bur I don't remember which one worked finally. Just try them all with no harry and one will work.
thanks mate
that gives me hope it works :thumbup:
wahidhussain
06-08-2017, 02:32 AM #10
thanks
thanks mate
Views 558
29-03-2018, 06:50 AM
Last Post by jasons
Views 809
20-03-2018, 10:28 AM
Last Post by jasons
