JapCarForum Cars, Cars, Cars! General Car Maintenance Smoking on cold start up
Pages (3): 1 2 3 Next
06-08-2017, 06:40 AM
Ok been meaning to post this up for a while, been getting a dark greyish/black smoke on cold start ups now and again, after a few revs it clears up.....having done a little reading around it seems that it could be the valve seals or the pcv valve (positive crankcase ventilation). With the latter being a couple of quid part i think i will replace it to see if helps, can anyone point me in the direction of where how i can get to it pics would be great if possible (hint hint Ormi Smile )
ive also read that a thicker oil may help, as thinner oil may seep through the seals, i dont really think this is the case, however bit coincidental that this started a while after i changed to a thinner oil !
Anyone with any other suggestions?!
06-08-2017, 06:40 AM #1
06-08-2017, 06:52 AM
Are you using the correct oil for the car. i.e what Lexus say to use.
06-08-2017, 06:52 AM #2
06-08-2017, 07:10 AM
im using 5-30 which is with within the 'acceptable range' of grade and the recommendation of opie.....there are others that are using it too so dont really think its an issue?
06-08-2017, 07:10 AM #3
06-08-2017, 09:06 AM
my suggestion is .... it's kna******, skip it & get a Supe Smile
06-08-2017, 09:06 AM #4
06-08-2017, 09:14 AM
purplewitch my suggestion is .... it's kna******, skip it & get a Supe Smile
Highly constructive. Big GriniscoStu:
06-08-2017, 09:14 AM #5
06-08-2017, 09:18 AM
Sam's answer to everyone's car troubles...
Although she forgets if we all do that then there will be less for her to own...
06-08-2017, 09:18 AM #6
06-08-2017, 09:20 AM
And we could accidentally crash one and be forced to post pictures of broken Supes........
06-08-2017, 09:20 AM #7
06-08-2017, 09:23 AM
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeks.. forget car mechanics according to Sam... fix it Shahz!!
06-08-2017, 09:23 AM #8
06-08-2017, 09:36 AM
:lol:
06-08-2017, 09:36 AM #9
:lol:
06-08-2017, 09:47 AM
you could buy a grey Supe , they are very common
06-08-2017, 09:47 AM #10
Views 477
18-01-2020, 02:14 AM
Views 691
10-10-2017, 12:39 PM
Last Post by fluff
Views 425
11-08-2017, 12:21 AM
