JapCarForum Cars, Cars, Cars! Car Care & Detailing Zorst cleaning...
Zorst cleaning...
Zorst cleaning...
jomo
19-08-2017, 03:02 PM
Has anyone polished up their IS200 s/steel zorst?
If so how easy/long did it take?
Also any pics?
jomo
19-08-2017, 03:02 PM #1
Also any pics?
Fry-Up
20-08-2017, 08:46 AM
Bandit Cleans and polishes anything and everything that his time allows for, he's probably the best chap for advice on this subject,
I had a go at doin just the exhaust tip but it came out rubbish, still marked lol
Fry-Up
20-08-2017, 08:46 AM #2
OddScoobyMike
17-09-2017, 09:20 AM
i dont know if it would be any different for an is200 as for the mr2, but i used a mixture of autoglym metal polish and 3.5k grit micromesh, works a treat. As far as i know though, micromesh is quite tricky to get hold of, especially the really fine stuff.
OddScoobyMike
17-09-2017, 09:20 AM #3
OddScoobyMike
17-09-2017, 09:25 AM
Saying that:
http://www.relishmodels.co.uk/alclad-ii-...h-set.html
Bit of info
http://www.ss-sci.com/micromesh.htm
if you go down that road, dont go too harsh, you will forever be polishing the fine scratches out. I had a go with 32k micromesh, its time consuming!!
OddScoobyMike
17-09-2017, 09:25 AM #4
Saying that:
Bit of info
Tango
17-09-2017, 09:35 AM
I've always found fine grade wire wool and Autosol metal Polish works well Cool
Tango
17-09-2017, 09:35 AM #5
OddScoobyMike
17-09-2017, 09:50 AM
wire wool isnt the best stuff to use on anything metal, you can cause an electrolytic reaction called dissimilar metal corrosion, its not ideal.
OddScoobyMike
17-09-2017, 09:50 AM #6
Tango
17-09-2017, 11:11 AM
OddScoobyMike wire wool isnt the best stuff to use on anything metal, you can cause an electrolytic reaction called dissimilar metal corrosion, its not ideal.
'Anything metal'?? Galvanic corrosion as you describe would only be a risk in this situation if you leave the stainless steel in contact with the carbon steel wire wool, or bits of it that may break off of it. Polishing the surface as you need to do after applying the Autosol removes any traces of carbon steel, and the risk of extended galvanic corrosion.
What's the risk of short term exposure? The difference in anodic index is probably less than 0.25V.
Tango
17-09-2017, 11:11 AM #7
E55EX_RACER
18-09-2017, 01:41 AM
Tango I've always found fine grade wire wool and Autosol metal Polish works well Cool
+1, great stuff
E55EX_RACER
18-09-2017, 01:41 AM #8
+1, great stuff
OddScoobyMike
18-09-2017, 02:45 AM
Tango 'Anything metal'?? Galvanic corrosion as you describe would only be a risk in this situation if you leave the stainless steel in contact with the carbon steel wire wool, or bits of it that may break off of it. Polishing the surface as you need to do after applying the Autosol removes any traces of carbon steel, and the risk of extended galvanic corrosion.
Thats why stainless steel exhausts rust, because of the electrolytic reaction.
Unless you do the whole thing, you cant guarantee getting all the bits from the wire wool off. personally, and its only my opinion, i wouldnt. Blush
OddScoobyMike
18-09-2017, 02:45 AM #9
Tango
18-09-2017, 03:57 AM
Well the Tanabe Stainless system on my IS250 still comes up like new and it's been on the car for around four years.
Tango
18-09-2017, 03:57 AM #10
Views 1,474
14-12-2018, 09:47 AM
Views 1,167
18-03-2018, 07:26 AM
Last Post by Fry-Up
Views 1,345
09-12-2017, 04:00 AM
Views 668
16-11-2017, 09:18 AM
Views 1,067
05-05-2017, 09:32 PM
Views 1,102
20-12-2016, 11:34 AM
Last Post by Bandit
Replies 36
Views 2,706
06-08-2016, 11:16 AM
Last Post by Bobby
Views 632
04-06-2016, 01:45 AM
Views 445
11-05-2016, 09:46 PM
