JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza passanger air bag switch
Pages (3): 1 2 3 Next
28-08-2017, 07:55 AM
has anybody fitted a airbag disable switch so you can have kids in the front? if so what switch did you get and any info on how to fit it would be great. thanks:laugh:
28-08-2017, 07:55 AM #1
28-08-2017, 09:01 AM
Is it not just a matter of putting a switch in the wire?
You could fit it on the little panel at the side of the dash that you can see when you open the door, it pops out to help mount the switch.
28-08-2017, 09:01 AM #2
29-08-2017, 12:25 AM
well got myself a switch from ebay from a skoda that fits in the glovebox. just thinking about the warning light. you think i will get on on my cluster
29-08-2017, 12:25 AM #3
29-08-2017, 01:37 AM
i would have thought if you disconect the wire from it, then it would through up a airbag error in the process may render the rest of the airbags useless in an accident (whilst disconnected)
you could find the resistance of the airbag you want to disable locate the plug cut in there and chuck a resistor in thus disabling the airbag without the warning light....
29-08-2017, 01:37 AM #4
29-08-2017, 02:14 AM
It wont disable the rest, but will bring up an airbag light.
like rab said a resister will prevent this. you could have a double switch so it breaks both wires to the aribag and instead joins the circuit to a resistor so the car still think its there.
29-08-2017, 02:14 AM #5
29-08-2017, 02:16 AM
I think in some (maybe not lexus) when the airbag circuit detects a fault it disables the rest of the airbags as the circuit has a malfunction...
i know it did this in my vectra and im sure my estate is the same or so the garage told me lol not that i trust garages nowadays
29-08-2017, 02:16 AM #6
29-08-2017, 03:37 AM
brought this one
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...RT:GB:1123
just must find out how to put it in with a resistor so as not to kill the other ones
29-08-2017, 03:37 AM #7
brought this one
29-08-2017, 03:40 AM
any idea what type of resistor i need. anybody have the spec on the main airbag front passanger indash unit
29-08-2017, 03:40 AM #8
Fozzy
29-08-2017, 04:31 AM
Rabster is right, any sort of error detected in the airbag system will disable the entire system. Im surprised the car doesnt have something fitted as standard to disable the passenger airbags. Most cars have this function
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
29-08-2017, 04:31 AM #9
29-08-2017, 05:11 AM
I would think twice about measuring the resistance across the airbag. The LS400 workshop manual I have says that doing that will set it off. There's a whole page long warning telling you not to do it Wink
29-08-2017, 05:11 AM #10
Replies 18
Views 876
06-11-2016, 07:46 AM
Views 316
27-05-2016, 03:40 AM
Last Post by reganlives
