JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Tein upper mounts
Tein upper mounts
Tein upper mounts
TimmyK
31-08-2017, 12:18 AM
Seen them on camskill but what do they do? Do you need coilovers or can they fit with OEM suspension/lowering springs
Car 1 - 02 Lexus IS200 SE Strathcaron Blue, Sport Grille, TTE Lowering Springs (to be fitted), K&N Panel Filter, 6500K XENON Headlight Main & Dipped Bulbs, Xenon Sidelights, 17" Gunmetal Powder Coated Alloys, Front Grooved Discs and Mintex Pads
Car 2 - 73 Hillman Imp AKA Hilda, Aquarious Blue, work in progress!
TimmyK
31-08-2017, 12:18 AM #1
Fozzy
31-08-2017, 01:01 AM
Standard top mounts are made from rubber, and so flex a bit under load. The tein topmounts removes all the rubber and replaces it with a spherical bearing. This will reduce the play on the strut, but will transmit a bit more road 'noise' through the chassis. They also allow for adjustment of the camber and caster settings.
They will work fine with standard struts and lowering springs
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
31-08-2017, 01:01 AM #2
TimmyK
31-08-2017, 01:06 AM
Ah right brill thanks buddy take it you can fit strut brace with these too
TimmyK
31-08-2017, 01:06 AM #3
Fozzy
31-08-2017, 01:08 AM
I dont see why not. They still fit to the underside of the turret, so where the strut brace mounts will be the same as standard
Fozzy
31-08-2017, 01:08 AM #4
Views 225
18-10-2021, 01:58 AM
Views 254
31-03-2020, 11:39 AM
Last Post by argyle dan
Replies 22
Views 1,453
21-05-2017, 10:46 AM
Last Post by ormi
Views 626
17-01-2017, 12:44 AM
