injector help
injector help
what injectors are people using on here for the turbo is200`s?
looking to buy some new ones.
does the altezza use the same injectors?
thanks
i used 315 cc from a 1g gte engine but you will need you take a dremil to your head.
others are using these
http://www.powerenterpriseusa.net/produc.../index.htm
but you will have to have a very good piggyback ecu to run them.
also there are injectors from other toyota's that fit.
I am using the Power Enterprise 550cc injectors. The correct part number to order for those is TH-550A-C. Yes, the Altezza uses the same injectors, *but* the Altezza has a different electrical connector to the injectors. That part number that I mentioned is for the MR2 MkIII, which uses the same injectors and the same connector.
steviewevie I am using the Power Enterprise 550cc injectors. The correct part number to order for those is TH-550A-C. Yes, the Altezza uses the same injectors, *but* the Altezza has a different electrical connector to the injectors. That part number that I mentioned is for the MR2 MkIII, which uses the same injectors and the same connector.
dimis Do you mean the Altezza AS200?
This is the info i have gathered from the australian altezza club:
Found some information regarding the upgrade of the fuel injectors for the IS200. The altezza motor (3SGE) uses 340cc Denso injectors.
steve when i order them do i need the plugs to go with them or just the injectors??
LEX11S steve when i order them do i need the plugs to go with them or just the injectors??
thankyou steve just wanted to be sure :thumbup1:
seen some injectors on e-bay for £295.39 23.00 postage this is for 6 listed for are cars made by denso and they are 550 cc? any good
