JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Auto owners - consider a grounding kit
25-09-2017, 11:53 AM
Yeah yeah I know, grounding kits are generally perceived to be a load of loblocks.
However after reading a few threads elsewhere about how it helps with shifting on the IS auto's I thought I'd give it a go.
So I grabbed a basic kit from ebay for £40. Its basically some guy cutting thick gauge speaker cable to size and soldering connectors on the ends, but that's pretty much what they all are.
Anyway, fitted it this afternoon and managed to get it installed without loosing power and resetting the ECU (so i could get a proper feel for any real changes). Here's what I noticed:
- Slightly smoother idle
- Quicker changes when using e-shift
- Slightly quicker at starting up.
- Ever so slightly improved throttle response.
Not bad for £40 I figured :p
25-09-2017, 11:53 AM #1
25-09-2017, 12:13 PM
This kit?
http://cgi.ebay.co.uk/Lexus-IS200-specif...337wt_1139
25-09-2017, 12:13 PM #2
This kit?
25-09-2017, 12:14 PM
stavs car was used for the making of that kit..
heres the kit i got..its a voltage stabiliser
[Image: img0131hp.jpg]
[Image: p1004101916.jpg]
[Image: p1004101922.jpg]
25-09-2017, 12:14 PM #3
25-09-2017, 01:09 PM
Marsdendean You must be referring to the IS300, as the IS200 Auto does not have e-shift?
yeah 300's dean you should get one lol.
good find jim may have to try this as its not super expensive.
25-09-2017, 01:09 PM #4
25-09-2017, 01:33 PM
Sparkystav This kit?
Yarp thats the one matey.
I actually didn't know that. Just assumed they were the same. You should still benefit from some of the other bits though I guess?
25-09-2017, 01:33 PM #5
25-09-2017, 01:34 PM
ormi stavs car was used for the making of that kit..
Where did you ground to on urs?
I did: firewall area, drivers side near suspension strutt, near radiator, on alternator and on throttle body.
25-09-2017, 01:34 PM #6
25-09-2017, 11:14 PM
jimxms Yarp thats the one matey.
Should recognise the car in the pic then Wink
25-09-2017, 11:14 PM #7
26-09-2017, 12:24 AM
No wonder none of the cables fitted where they shudda done. The guy based it around an IS200 with a 1G-GTE engine :p
26-09-2017, 12:24 AM #8
26-09-2017, 12:28 AM
lol it was when i had the 1gfe.
hes a nice guy, very helpful i found
26-09-2017, 12:28 AM #9
26-09-2017, 01:00 AM
Here's the one I got:
http://cgi.ebay.co.uk/Lexus-IS300-2JZ-GE...53e24743f4
Unfortunately all the instructions were for a Supra, so I've taken some pics for the guy - maybe I'll get featured too :p
26-09-2017, 01:00 AM #10
Replies 45
Views 2,473
29-01-2018, 03:05 AM
