JapCarForum Cars, Cars, Cars! General Car Maintenance cat back exhaust help
29-09-2017, 03:20 AM
as the title says i recently bought a cat back exhaust but there is no hole for the sensor behind the cat box.
does it need to be fitted or shall i try and get it done.
whats the best way of doing it
any help will be greatful
29-09-2017, 03:20 AM #1
29-09-2017, 03:30 AM
You can get a hole fitted at an exhaust shop, they should be well used to doing that. Or replace the sensor with an O2 simulator.
29-09-2017, 03:30 AM #2
29-09-2017, 03:31 AM
whats an o2 simulator and what does it do
29-09-2017, 03:31 AM #3
29-09-2017, 03:36 AM
the simulater just makes the car think it has the sensor in it by controlling the voltage and frequencies that are sent back to the ecu heres a link to one on fleabay. and needs soldering into the system.
http://cgi.ebay.com/ebaymotors/Universal...arQ5fParts
29-09-2017, 03:36 AM #4
29-09-2017, 03:44 AM
would it be easier to just drill and weld a thread onto the new pipe
29-09-2017, 03:44 AM #5
29-09-2017, 04:19 AM
right just spoke to my mate in the metal shop at work this is the info i need so please help me if you can.
1. what is the thread patern
2. what is the thread size i.e 14, 15mm
3. where can i buy some stainless steel to make the thread
any help would be great
29-09-2017, 04:19 AM #6
Fozzy
29-09-2017, 04:54 AM
They are available on ebay, but any exhaust fabrication company should stock them and be able to fit them for you.
http://cgi.ebay.co.uk/Lambda-Sensor-Stai...4aa5a09fd6
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
29-09-2017, 04:54 AM #7
29-09-2017, 04:59 AM
and this will fit the is200 including the thread
29-09-2017, 04:59 AM #8
Views 420
21-04-2020, 12:58 AM
Last Post by Jon
Views 1,337
26-10-2018, 07:56 AM
Last Post by Gr1NcH
Views 530
09-03-2017, 09:24 AM
