JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Is it a myth?
Is it a myth?
Is it a myth?
Dave
13-10-2017, 11:23 AM
HI someone told me today that in the morning when starting your car its better to drive off than reverse off. apparently this is better for your engine.
can anyone shed any light on this?
[SIGPIC][/SIGPIC] LEXUS IS200 SE 2002. WOULD LOVE 2 KNOW HOW MANY IS200'S ARE IN THE UK.
Dave
13-10-2017, 11:23 AM #1
13-10-2017, 11:30 AM
Not sure mate maybe, as you may well know the reverse gear is straight cut and the other gears are helical gears. And the reason they dont use the straight cut gears in the other gears (1-6) is because it is not strong enough. So when reversing when engine is cold, the oil will be thicker and may not act as a lubricant up to what it could do when warm, so may cause strain on it?
Only what I think, but hey I'm only 14.
13-10-2017, 11:30 AM #2
Fozzy
13-10-2017, 12:05 PM
Straight cut gears are far stronger than helical cut gears, its simply the noise issue as to why they use helical gears. See race cars all run straight cut gear sets
I dont see how it will make any difference. Sounds like an old wives tale to me
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
13-10-2017, 12:05 PM #3
13-10-2017, 12:08 PM
Ah see i got it wrong Sad
13-10-2017, 12:08 PM #4
spikes
13-10-2017, 01:12 PM
Gord Might try reversing to work tomorrow, as the rear window clears 1st with ice on it :lol:
what no heated windscreen Gord:wink:
spikes
spikes
13-10-2017, 01:12 PM #5
spikes
mplavery
13-10-2017, 02:00 PM
If someone told me that i would bust out in lafter then walked away lol
Put it this way, have you ever heard someone say to another "that engine dont sound to good"
"thats because they reverse off then drive when they start the car"
Load of rubbish IMO mate, i have never heard this before
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
13-10-2017, 02:00 PM #6
[/COLOR]
[/COLOR]
14-10-2017, 12:57 AM
It's not like the engine is doing anything different in reverse to when it's in first, other than it being a slightly different gear ratio. Nonsense, methinks.
14-10-2017, 12:57 AM #7
14-10-2017, 01:09 AM
+1 for it being a myth.
14-10-2017, 01:09 AM #8
14-10-2017, 03:03 AM
Myth Busted.
14-10-2017, 03:03 AM #9
Myth Busted.
14-10-2017, 03:10 AM
What about if you have an automatic? :biggrin:
14-10-2017, 03:10 AM #10
