JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Koni shocks
Koni shocks
Koni shocks
TommyH
29-10-2017, 12:21 PM
Hello all, Would Koni shocks from a 300 sportscross fit the 200 ?
Thanks
TommyH
29-10-2017, 12:21 PM #1
Thanks
29-10-2017, 12:28 PM
i imagine so tommy Smile same shock but has a different spring, well my dads did? his 300 sportcross spring was thicker than 200 saloon?
29-10-2017, 12:28 PM #2
TommyH
29-10-2017, 12:36 PM
Thanks for the reply Oli :thumbup1:
TommyH
29-10-2017, 12:36 PM #3
29-10-2017, 12:43 PM
but a thicker spring would only mean a stiffer back? so not bad then?
29-10-2017, 12:43 PM #4
TommyH
29-10-2017, 01:12 PM
I was thinking of putting my own springs (cheap 40mm ones from e-bay) on with the koni dampers, if i get them.
TommyH
29-10-2017, 01:12 PM #5
ah ok fair enough mate
29-10-2017, 01:12 PM #6
TommyH
30-10-2017, 12:09 AM
Would it be ok to have Koni shocks on the front and OEM shocks on the rear ?
And would i have to get my Geometry redone ?
Thanks
TommyH
30-10-2017, 12:09 AM #7
Thanks
James S
30-10-2017, 12:19 AM
I'd say that you would have different damping rates front and back. Would probably mess up the handling.
Think you'd be ok putting your springs on the shocks though. Are they adjustable??
James S
30-10-2017, 12:19 AM #8
TommyH
30-10-2017, 01:20 AM
The guys only got the fronts for sale James, think they are damper adjustable. Think your right with the different damper rates, never thought of that mate.
TommyH
30-10-2017, 01:20 AM #9
