JapCarForum General Discussions The JCF Lounge Couple quick questions...
30-10-2017, 08:38 AM
Right,
I noticed there's been some slight scraping coming from the rear nearside of the car, mostly over speed bumps and stuff. At first I though it was just crud from the road in the wheel arch and the tyre was just rubbing it, but I had a look and there's something hanging down back there.
It's too dark to get a decent picture of it, but basically it's just in front of the rear wheels (not exhaust side) - is this likely to be something important? I'll try and get a picture tomorrow in the light, but awkward to get down to as well...
Also, discovered that there's an annoying squeak when I push in the clutch pedal today - sure it wasn't doing this the other week, so maybe this will clear itself up?
30-10-2017, 08:38 AM #1
Right,
30-10-2017, 08:50 AM
No idea what could be hanging down with no description or pics , could it be
[Image: 685eae28a64417ee4b2bfba7ebeb100e.jpg]
Give the pedal a spray of WD40 , but not the part you put your foot on Confusedhock:
30-10-2017, 08:50 AM #2
30-10-2017, 10:27 AM
:lol: Thanks Moley... :wink: ever helpful!
It looks like some part of the under shielding, it's right by the inner wheel arch trim, but until I can get a decent pic... it might as well be bananas Smile
Are you suggesting the wd40 get sprayed on the lever the pedal's attached to? That sounds like something even I could cope with :lol:
30-10-2017, 10:27 AM #3
01-11-2017, 05:36 AM
Well, I got under the car yesterday with the rear wheel off and it looks like a bit of the under shielding was cracked, and it had folder over itself, hence the scraping over speedbumps and such.
I just realigned it and shoved it back into place, no more scraping...
WD40 on the clutch has worked as well, so a touch of rep for the MoleMan Smile
Well, I would, but it won't let me unless I find someone else to rep first. So someone do me a favour or something... Smile
01-11-2017, 05:36 AM #4
01-11-2017, 05:45 AM
you could do some cable tie stitching on the cracked bits to stop it from coming loose again just drill a few holes each side of where its split and zip it together.
01-11-2017, 05:45 AM #5
01-11-2017, 05:51 AM
If you've used WD40 you'll find it will wear off, so your squeak will come back eventually. Best get some grease or spray some 3-in-1 on it.
01-11-2017, 05:51 AM #6
01-11-2017, 07:26 AM
is300_dino you could do some cable tie stitching on the cracked bits to stop it from coming loose again just drill a few holes each side of where its split and zip it together.
Good tip Smile but sounds like work... Sad
If it comes loose again though, I'll do that Smile
toxo If you've used WD40 you'll find it will wear off, so your squeak will come back eventually. Best get some grease or spray some 3-in-1 on it.
I'll see what I can find in the garage Smile thanks for the heads up
01-11-2017, 07:26 AM #7
edeath
01-11-2017, 09:00 AM
Yep my Cupra has also grown a mouse on the clutch pedal. It goes away after about 15 mins. Its the cold - should stop once it warms up a bit.
edeath
01-11-2017, 09:00 AM #8
Views 177
09-05-2020, 02:54 AM
Views 197
10-07-2019, 02:09 PM
Last Post by Easterlow
Replies 49
Views 2,211
29-04-2019, 02:23 AM
Replies 18
Views 572
20-02-2019, 04:22 AM
Views 309
24-01-2019, 12:01 PM
Last Post by Kevpr
Views 672
05-10-2018, 01:14 AM
Last Post by jimxms
Views 414
27-07-2018, 11:42 PM
Last Post by bash6673
Views 377
12-06-2018, 11:35 AM
Last Post by jimxms
