JapCarForum Trade Area Trade Archive Wanted Archive Limited Slip Diff
Limited Slip Diff
Limited Slip Diff
James S
03-12-2017, 08:32 AM
Just standard LSD from a Sport model.
Don't want to pay through the nose.
Also if anyone has any suspension components lying around I might be interested, things like wishbones, but mainly the lower arms.
James S
03-12-2017, 08:32 AM #1
04-12-2017, 12:23 AM
have you tried 24/7 spares mate
might find one there at a good price
04-12-2017, 12:23 AM #2
James S
04-12-2017, 01:03 AM
I haven't, bit dubious about trying a salvage place as I couldn't identify it from the outside! Don't want to pay good money for a diff I already got! LOL!
James S
04-12-2017, 01:03 AM #3
04-12-2017, 02:02 AM
Your right, the outside of a LSD looks identical to the outside of a normal one. Only the Altezza RS200 has a different shell, that one has cast heat dissipation fins on the underside.
You can't tell by turning the wheels either, you have to take the back end off to see what's inside.
The Altezza one will fit the IS200 BUT you have to change over the drive shafts also, as there are more bolts on the IS200 ones.
04-12-2017, 02:02 AM #4
04-12-2017, 03:37 AM
Could you not just find a sport being scraped and go remove it yourself then you would know for sure
04-12-2017, 03:37 AM #5
04-12-2017, 03:39 AM
Lexuspat Could you not just find a sport being scraped and go remove it yourself then you would know for sure
not every Sport had them, you have to check the VIN plate
04-12-2017, 03:39 AM #6
04-12-2017, 03:45 AM
I did not know that cheers satv
I thought all sports had an LSD
Learn something new every day
04-12-2017, 03:45 AM #7
04-12-2017, 04:30 AM
Sparkystav not every Sport had them, you have to check the VIN plate
I didn't know that either, I thought they all had one?
04-12-2017, 04:30 AM #8
04-12-2017, 05:29 AM
Some of the earlier ones didnt apparently.
If you want to check to make sure you have an LSD you will need to look at your VIN plate under the bonnet.
If it ends in "B" then it's LSD. If it ends in "A" then you have an open diff.
It'll say something like A02B
Edited 15-01-2011, 03:06 PM by Sparkystav.
04-12-2017, 05:29 AM #9
James S
04-12-2017, 09:11 AM
Hense the reason I posted a up in the wanted section LOL! Lazy me would like someone to just hand me one on a plate! :p
James S
04-12-2017, 09:11 AM #10
Views 314
14-02-2018, 11:54 AM
Last Post by James S
Views 550
30-11-2016, 03:33 AM
