JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza condesation
condesation
condesation
danovstbudo
09-12-2017, 12:20 PM
I got my 1st is200 this week:thumbup1:, there are a couple of things that in not sure about but might be common problems? when ever i get in the 1st thing it starts no problem but the oil light stays on untill i pull away then goes out? also there is condensation inside the car is there any common places they leak to? any help thanks
danovstbudo
09-12-2017, 12:20 PM #1
danovstbudo
09-12-2017, 12:29 PM
se and has sunroof the rear window is alwas worse will check the boot carpet tomoro,are the pipes easy to get to.
danovstbudo
09-12-2017, 12:29 PM #2
09-12-2017, 12:32 PM
The boot is the main area for holding water mate, if you pull the boot carpet up at both ends (left +right sides) there's sometimes a puddle of water in both sides of the boot floor? there are rubber grommets in them at the bottom that you can pop out if there is water in them?
I took my grommets out and left them out and its not been too bad since, but i also use Rain-X, Anti-Fog on the windows which pretty much eliminates any condensation? :thumbup1:
09-12-2017, 12:32 PM #3
09-12-2017, 01:43 PM
Smile Is that one product or two Chris?
The inside of my sunroof has a fair bit of condensation in the cold weather, but nothing anywhere else so far Smile
09-12-2017, 01:43 PM #4
10-12-2017, 12:28 AM
Yeh its Anti-fog made by Rain-x mate, works very well, also used the rain-x water repellent in the past and that's very good? rain just seems to run off the screen when driving without the need to use the wipers? :thumbup1:
10-12-2017, 12:28 AM #5
danovstbudo
10-12-2017, 07:37 AM
any idears on the oil light anyone
danovstbudo
10-12-2017, 07:37 AM #6
10-12-2017, 07:47 AM
Very common if the car has a non Toyota/lexus oil filter as some of them have no anti return valve check the filter.
10-12-2017, 07:47 AM #7
Phil01
10-12-2017, 10:19 AM
does the light only go out when you pull away in gear, so if you let it idle will it illuminate all the time??
Phil01
10-12-2017, 10:19 AM #8
