JapCarForum General Discussions The JCF Lounge Towing a vehicle
Towing a vehicle
Towing a vehicle
14-12-2017, 04:11 AM
What are the doos and donts
Can you tow a rear wheel drive vehicle on a 2 wheel dolly like the type the RAC and AA have ?
can you tow a vehcile with an AUTo Box the same way as above ?
if not how do you tow an Auto or is it a full lift job ?
14-12-2017, 04:11 AM #1
14-12-2017, 04:49 AM
I think you have to tow a RWD car the other way round, with the front wheels on the ground. Again it's the same situation with an auto, the drive wheels shouldn't be on the ground.
Best to get a flatbed though if you can.
14-12-2017, 04:49 AM #2
Mikey
14-12-2017, 04:53 AM
dont ever tow a auto car on the drive wheels
Mikey
14-12-2017, 04:53 AM #3
14-12-2017, 04:57 AM
A manual rwd is ok to tow with the rear wheels on the ground.
A auto NEVER tow alway flat bed it
14-12-2017, 04:57 AM #4
mplavery
Just asked a few people at work as im not to sure, They seem to think that it would be ok to tow a rear wheel drive from lifting the front if its MAN but you cant do it if its a Auto
Its only what i have been told though lol
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
14-12-2017, 04:57 AM #5
[/COLOR]
[/COLOR]
14-12-2017, 05:07 AM
If you drop the prop, or remove the drive shafts then you can tow an auto on the drven wheels - easier to flat bed it.
14-12-2017, 05:07 AM #6
14-12-2017, 06:09 AM
ormi A manual rwd is ok to tow with the rear wheels on the ground.
Unless it's an MR2 - the pump gear that circulates the transmission oil around the gearbox and through the little cooler loop is attached to the input shaft not the output / diff. So when you have the rear wheels going round on the road and it's not in gear, the oil is never circulated around the box and it boils.
14-12-2017, 06:09 AM #7
14-12-2017, 06:30 AM
Thanks guys it's confirmed my fears lol
14-12-2017, 06:30 AM #8
Phil01
14-12-2017, 09:06 AM
A awful lot of auto cars can be towed with a max of 30mph and a max distance of 30 miles
so yes you can tow autos but check in owners handbook first
The only exceptions which are a definite "no no" is the Toyota Prius and any type of Black Cab Taxi with auto box.
Andy just tell me what car you need to tow and I can tell you the limitations
Phil01
14-12-2017, 09:06 AM #9
Views 268
06-10-2018, 03:38 PM
Last Post by clossie
Views 401
15-07-2017, 01:39 PM
Last Post by garyskisplym
Views 167
21-06-2017, 10:29 PM
Views 268
28-08-2016, 10:24 AM
Last Post by russelllinn
