JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Generic Push Start Button & Proximity Entrance
Pages (8): 1 2 3 4 58 Next
17-12-2017, 12:28 PM
OK well this is following on from the group buy here
As discussed a lot of you would like to see this system in the flesh and know how easy it is to install, so i went ahead and got 2 kits, to be experimented on 2 different types of set ups
So here is the good news
they are here in my flat ready to rock and roll
[Image: 50e9ffde.jpg]
[Image: ab3a8ef8.jpg]
[Image: 3eee3432.jpg]
[Image: b4d52cd3.jpg]
If i get a chance this weekend i will get the push start part of the system installed so you can all see that running the proximity bit needs a bit of research as i have an after market alarm.
If i can however Fit this into mine then all those with After market alarms on any vehicle will be able to do the same.
I will do a full write up and picture install thread on this kit once it has been evaluated.
17-12-2017, 12:28 PM #1
17-12-2017, 12:31 PM
This is great mate. Are you sure you want to sell the Lexus? I be you will regret it at the end of the day
17-12-2017, 12:31 PM #2
17-12-2017, 12:44 PM
So this cannot be fitted to OEM alarms?
17-12-2017, 12:44 PM #3
17-12-2017, 12:50 PM
i didnt say that oli
17-12-2017, 12:50 PM #4
17-12-2017, 12:54 PM
I pretty sure it can be Oli.
17-12-2017, 12:54 PM #5
Chri5
17-12-2017, 01:00 PM
That looks like a lot of hard work to wire in Sad
Chri5
17-12-2017, 01:00 PM #6
18-12-2017, 02:48 AM
So is this the proper system out of Toyotas, or is it just the switch and the rest is aftermarket?
Either way interested to see how this progresses :biggrin:
18-12-2017, 02:48 AM #7
Fozzy
18-12-2017, 03:16 AM
Just the switch is from Toyota, the rest is an aftermarket kit from the US, Hopefully this will be a little easier to get up and running than our homebrew system!
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
18-12-2017, 03:16 AM #8
18-12-2017, 03:21 AM
im interested too lets see how this works
18-12-2017, 03:21 AM #9
18-12-2017, 09:42 AM
Ok well we have success
I first installed the item as single button use
This means that you have to hold down the button in order to start the car (not much fun)
however it worked
I then moved onto the Tach sensing part of the circuit very awkward to program instructions not that clear, once done works a treat
i spotted a down side however without the Keyless part installed the system requires the button to be grounded to activate now if you ground it permenatly, car wont start if the imobiliser is still activated. however i worked a way round this on mine that im sure can be developed on a standard car...
the following is how i have set up and configured in my car this is using an aftermarket alarm and imobiliser. not using the keyless system at the moment.
Rabster IS200 2002 turbo with CLifford Avantguard 5.5 Security System
Starting Car
Step one: Aproach Car and unlock using G5 Remote (start switch illuminates)
Step Two: Open Car door Get in
Step three: PLace foot on brake Pedal (start switch will be flashing amber now)
Step Four: press Start button once (engine will start)
Step Five: remove foot from brake pedal
To turn off Car
Step one: PLace foot on brake pedal
Step two: Press and hold Start switch till engine stops
18-12-2017, 09:42 AM #10
however it worked
Starting Car
To turn off Car
Views 663
30-03-2021, 03:12 AM
Last Post by Millo73
Views 1,384
25-12-2017, 01:07 PM
