JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Had My First MOT today
Fry-Up
30-12-2017, 08:03 AM
I've had the car just over 12 months now and it had 12 months MOT on from time of purchase, albeit with the wrong reg number from the garage which I had altered no problem
I was worried it would fail as due to the age and mileage of the car, I thought maybe ball joints would have a little excess play, since my IS200 failed on the same when it had similar mileage, also since I had a minor bump in OCT, the seals in the headlamps gradually deteriorated and after the bad winter condensation started to form in the drivers side lens, since finding out that if the moisture doesn't affect the beam pattern then it may not fail the test,
I set about drying it out, by this time (last week) the passenger side one might as well have had a bucket of water funneled in over night as the sidelight bulb and headlight stopped working, so I whipped that off aswell, and had a look at the video on Youtube about opening up the lamps and sealing them up again (halo/angel eye install vid)
Oven packed up, so I couldn't even heat them at home Sad I went to my brothers house and heated one up, I did the drivers side although I should have done the passenger one first as it was far worse, but i've never been much of a thinker...
Heated the oven to 120 c and stuck it in for 20 mins, by then the cheese was golden brown and bubbling slightly, so I took out my food and stuck the headlight in, for a further 20 mins, and took it out, and started to pull away at the lens, I didn't have any gloves so found it hard to keep hold of the thing whilst it was hot but the lens started to come away and I set about carefully, the parts where it clips in, with a screwdriver, but the last 2 clips wouldn't budge so I got as much fluid out as possible and squeezed the unit back together, and used silicone seal around the edge as best I could, I didn't even attempt the second lamp as i'd lost patience, so I attached some absorbant material to a cooking skewer and stuck it in through one of the bulb holes and mopped out as much fluid as I could, and went around the edge with silicone again just for good measure, I knew this wouldn't be a great success so my aim was just to get them as dry as possible for the MOT, which I did
MOT Failed,
on what??.......
i'd forgotten to put the bl00dy sidelight bulbs back in Sad other than that, no advisories whatsoever, i'm a happy little idiot to say the least
Edited 10-02-2011, 05:52 PM by GH.
Fry-Up
30-12-2017, 08:03 AM #1
MOT Failed,
on what??.......
Fry-Up
30-12-2017, 08:04 AM
title should read 'Had My First MOT Today'
Fry-Up
30-12-2017, 08:04 AM #2
30-12-2017, 08:06 AM
:laugh:
Good stuff! Always good when it passes, always funny when it fails cos you made an **** of something Big Grin
30-12-2017, 08:06 AM #3
:laugh:
30-12-2017, 08:07 AM
Re the title, I did think you were announcing a birth... Big Grin
30-12-2017, 08:07 AM #4
Fry-Up
30-12-2017, 08:08 AM
I hit the enter key when I went for the shift, i'd already pasted the main content so it submitted
Fry-Up
30-12-2017, 08:08 AM #5
Fry-Up
30-12-2017, 08:10 AM
also buys me 12 months to find some darker lamp units from the 2003-2005 model 300
Fry-Up
30-12-2017, 08:10 AM #6
Fry-Up
30-12-2017, 09:26 AM
Cheers for the Edit Big Grin
Fry-Up
30-12-2017, 09:26 AM #7
Replies 25
Views 1,205
25-08-2019, 10:27 AM
Views 311
20-07-2018, 01:40 AM
Last Post by Fozzy
Views 521
27-04-2018, 05:49 AM
Last Post by jimxms
Views 1,054
12-06-2017, 06:13 AM
Views 312
20-05-2017, 08:55 AM
Last Post by JeffMcC
Replies 24
Views 999
29-04-2017, 10:01 AM
Last Post by James S
Replies 34
Views 1,426
27-01-2017, 01:41 PM
Last Post by ormi
Views 723
25-12-2016, 04:50 PM
Last Post by Bandit
Views 262
30-10-2016, 02:12 PM
Last Post by Bandit
Views 530
19-09-2016, 04:08 PM
Last Post by Fry-Up
