JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Toyota Altezza spec lists for RS200 and AS200..
02-01-2018, 01:47 AM
Bit of the RS200/AS200 spec sheets... not sure how accurate it is but gives you and idea on comparison of both models? Big Grin
Toyota Altezza RS200 dimensions & weight
Wheelbase 2670 mm 105.1 in
Track front 1495 mm 58.9 in
rear 1485 mm 58.5 in
Length 4400 mm 173.2 in
Width 1720 mm 67.7 in
Height 1410 mm 55.5 in
Length:wheelbase ratio 1.65
Ground clearance 135 mm 5.3 in
Kerb weight 1340 kg 2954 lb
Fuel capacity 60 litres 13.2 UK Gal 15.9 US Gal
Toyota Altezza RS200 engine
Bore × stroke 86.00 mm × 86.00 mm 3.39 in × 3.39 in
Cylinders Inline 4
Displacement 2 litre 1998 cc (121.925 cu in)
4 valves per cylinder 16 valves in total
Compression ratio 11.50:1
Fuel system EFi
Maximum power JIS 212.9 PS (210 bhp) (156.6 kW) @ 7600 rpm
Specific output JIS 105.1 bhp/litre 1.72 bhp/cu in
Maximum torque JIS 216.0 Nm (159 ft·lb) (22 kgm) @ 6400 rpm bmep 1358.5 kPa (197 psi)
Specific torque JIS 108.11 Nm/litre
Manufacturer Toyota
Engine Code 3S-GE
Unitary capacity 499.5 cc per cylinder
Aspiration Normal
Catalytic converter Yes
Power-to-weight Ratio 156.72 bhp/ton
Toyota Altezza RS200 chassis
Engine location Front
Engine alignment Longitudinal
Drive Rear wheel drive
Turning circle 10.20 m
Tyres front 215/45 ZR 17
rear 215/45 ZR 17
Transmission 6 speed manual
Top gear ratio 0.87
Final drive ratio 4.10
Toyota Altezza AS200 dimensions & weight
Kerb weight 1310 kg 2888 lb
Toyota Altezza AS200 engine
Bore × stroke 75.00 mm × 75.00 mm 2.95 in × 2.95 in
Cylinders Inline 6
Engine code 1G-FE
4 valves per cylinder 24 valves in total
Compression ratio 10.00:1
Fuel system EFi
Maximum power JIS 162.2 PS (160 bhp) (119.3 kW) @ 6200 rpm
Specific output JIS 80.1 bhp/litre 1.31 bhp/cu in
Maximum torque JIS 200.0 Nm (148 ft·lb) (20.4 kgm) @ 4400 rpm
bmep 1257.9 kPa (182.4 psi)
Specific torque JIS 100.1 Nm/litre
Manufacturer Toyota
Bore/stroke ratio 1
Unitary capacity 333 cc per cylinder
Aspiration Normal
Power-to-weight 122.14 bhp/ton
Toyota Altezza AS200 chassis
Thought i'd add it as don't think we have much info on the altezza models? Big Grin
02-01-2018, 01:47 AM #1
Cylinders Inline 4
Fuel system EFi
Manufacturer Toyota
Engine Code 3S-GE
Aspiration Normal
rear 215/45 ZR 17
Top gear ratio 0.87
Cylinders Inline 6
Engine code 1G-FE
Fuel system EFi
Manufacturer Toyota
Bore/stroke ratio 1
Aspiration Normal
02-01-2018, 03:24 AM
But doesn't the AS200 use a 1G-FE engine, there it says 160bhp, but on the IS200's it's only like 153bhp?
02-01-2018, 03:24 AM #2
02-01-2018, 04:22 AM
Rep added for useful info :thumbup1:
02-01-2018, 04:22 AM #3
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Views 314
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 236
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 275
05-12-2019, 02:23 AM
Last Post by Reject1970
Views 304
01-10-2019, 05:15 PM
Last Post by PETEHAMASAKI
Views 611
21-07-2019, 10:57 AM
Last Post by Chris0121
Views 402
18-06-2019, 03:14 AM
Last Post by Kevpr
Views 387
23-05-2019, 12:27 PM
