IS350 wheels on Ebay !
Wonder how these would look on a IS200/300?
http://cgi.ebay.co.uk/4-Lexus-IS350-allo...7C294%3A50
Not sure if theyd be a tad too wide (being 8")
but would look good IMHO
No point in upgrading your wheels if they are the same size.
Most people would want to go up to 18" or even 19" when spending money on new wheels.
They're Dave Ellens wheels from his Tom's S/C IS350 but they're exactly the same wheels as the 17" IS250 rims. I also have a full set in my garage with Bridgestone Potenza's if anyone wants to make me a decent offer. They have a lot of tread still, as they've only done around 6000 miles. Wozza has a set of IS250 rims on his IS200, but they're 18".
i didnt look at the seller to be honest.
I wouldnt buy from them myself
but its anyones own choice
Are these wider than the same alloys on the IS250 then? I'm sure someone has IS250 alloys on an IS200 or Altezza, and Wozza has the 18" ones on his.......
All four are 8" wide, same as the 250. The staggered set up on the 17" rims is achieved with wider tyre width. The 18" IS250 rims like Wozza has on his IS200 are 18x8" wide on the front and 18x8.5" on the rear.
My 250 has 19x8.5" rims on the front and 19x9.5" on the rear.
The offset on the 17" 250 rims are OK on the IS200 providing you grind off the raised lug on the front suspension vertical arm.
I did a thread on the other forum a while back when I was able to get a full set cheap but didnt get the set as couldnt make my mind up and they didnt come with tyres but I shoulda really got them seeing as they were going for...£50 starting bid on ebay lmao...
IIRC u need to grind something away to make some clearance for them to fit on an IS200 as they're slightly wider.
