JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Smoke from engine
Smoke from engine
Smoke from engine
12-01-2018, 12:01 PM
Well as its been said in the "car of the month" thread my car had some smoke coming from it on Sunday so heres why.
When i pulled up after a long journey some smoke was coming from the engine, upon opening the engine it was found coming from the turbo blanket, when that was removed the smoke went with it lol.
I had a look today properly with the car running and discovered some weeping on the top turbo oil feed.
[Image: 605_large.jpg]
you can see the arrow in the pic.
speaking to Steve at Silverline, as usual he was extremely helpful and told me i can undo the fitting and trim it back then reseal it. So i will do that at the weekend.
So i think under pressure of high revs some oil has seeped out and got on the blanket hence the smoke - hot oil (100C) onto extremely hot turbo (more than 100C) equals smoke.
The squeaking is the power steering pump, but ive got one to replace it with that i bought and refurbed myself with new seals and a good clean.
Will put some pics up of making the fitting up as its something that could help members when they venture into Turbo country lol.
12-01-2018, 12:01 PM #1
12-01-2018, 12:13 PM
glad youve got it all sorted out mate
12-01-2018, 12:13 PM #2
12-01-2018, 12:48 PM
good stuff that you got it sorted.
12-01-2018, 12:48 PM #3
12-01-2018, 01:17 PM
better get it sorted before we have another fire in the family .
and not sure if you deserve my car of the month vote now :whistling:
12-01-2018, 01:17 PM #4
LEX11S
17-01-2018, 06:08 AM
This must be the month for oil leaks my return line had a leak on it and did the same as yours stav lol. hope you got it sorted
LEX11S
17-01-2018, 06:08 AM #5
17-01-2018, 06:20 AM
easy fix!! there the ones we like.
17-01-2018, 06:20 AM #6
17-01-2018, 06:26 AM
I take it you know the tricks for cutting braided hose, i.e. put tape around the bit you're cutting so that the ends don't fray etc.
At least it's an easy fix!
17-01-2018, 06:26 AM #7
17-01-2018, 07:06 AM
Yeah ive sorted it now, no sign of leaks.
just need to burn off the oil now thats got onto the blanket lol
Burned off a fair bit this morning on the local private bypass against a Supra, thing he needs to go back to the tuners Wink
17-01-2018, 07:06 AM #8
17-01-2018, 07:29 AM
Glad it was nothing major Stav:thumbup:
17-01-2018, 07:29 AM #9
17-01-2018, 07:47 AM
Sparkystav Yeah ive sorted it now, no sign of leaks.
was it a n/a :p ?
17-01-2018, 07:47 AM #10
was it a n/a :p ?
Views 309
13-07-2023, 10:07 AM
Views 531
15-10-2020, 10:35 AM
Views 1,481
26-06-2020, 09:41 AM
Last Post by Stoney
Replies 22
Views 1,655
29-01-2018, 12:41 PM
Last Post by DK_KARL
Views 297
25-12-2017, 08:43 PM
Last Post by Bandit
Views 321
14-08-2016, 08:51 AM
